BT.com
Wishlist
Sharp LC80LE657KN 80" Full HD, 3D, Freeview HD TV with USB Record
Delivery
Standard Due date unavailable
The AQUOS LE657 series uses the very latest Sharp image technology to give you the best possible viewing experience, no matter what you're watching - 2D or 3D.
Available in 80", the picture, with its natural colours, really comes alive and is rich in contrast and breathtaking depth. And what's more, the low energy consumption of the AQUOS LE657 means you get top image quality with efficiently low power consumption.
This TV is 3D capable and with AQUOS NET+ means you have access to your world of contents through internet connection.
Thanks to Netflix button on the remote commander, endless movie entertainment is in your hands.
Screen Size 80" (203 cm)
Full HD X-GEN panel (1920 x 1080)
Freeview HD built in
LCD TV with DIRECT FULL LED backlight
Active motion 200
AQUOS NET+ Internet Access
Netflix
USB Timeshift+ for easy programming and long availability of content
Sharp LC-80LE657KN Aquos LE657 - 80" 3D LED TV
LED-backlit LCD TV
Diagonal Class
80"
3D
Yes (3D glasses sold separately)
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Input Video Formats
1080p
Motion Enhancement Technology
Active Motion 200
Video Interface
Component, composite, HDMI, SCART
HDMI Ports Qty
4 ports
Wi-Fi, LAN
PC Interface
VGA (HD-15)
HDCP Compatible
UV²A
LCD Backlight Technology
LED backlight - full array, direct-lit LED
TV Tuner
1x analogue, 1x digital
Digital TV Tuner
DVB-S, DVB-S2, DVB-T, DVB-T2
Analogue TV Tuner
PAL, SECAM
Internet Streaming Services
Netflix, AQUOS Net +, HbbTV
Speaker System
2 speakers
Sound Effects
Virtual Dolby Surround
Supported Memory Cards
SD Memory Card
USB
Energy Class
Class A++
Power Consumption (On mode)
131 W
Energy Consumption per Year
182 kWh
186.2 cm x 43.4 cm x 114.5 cm
56 kg
LED-backlit LCD TV
Energy Class
Class A++
131 W
182 kWh
Diagonal Class
80"
Series
Aquos LE657
3D
TV Tuner
Video Interface
HDMI Ports Qty
4 ports
PC Interface
VGA (HD-15)
HDCP Compatible
Dimensions
With stand
186.2 cm
43.4 cm
114.5 cm
56 kg
Enclosure Colour
Display
LCD Display Technology
UV²A
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Active Motion 200
Brightness
350 cd/m²
Optical Picture Control (OPC), X-GEN panel, time-shift, ECO picture control (EPC), film dejudder
Stands & Mounts
Stand
Included
Stand Design
Tabletop
Flat Panel Mount Interface
600 x 400 mm
TV Tuner
Analogue TV Tuner
PAL, SECAM
Conditional Access
Common Interface Plus (CI+) slot
Reception System
SECAM-D, SECAM-B, SECAM-K, PAL-B, SECAM-G, PAL-G, PAL-I, PAL-D, SECAM-L, PAL-K
Digital TV Tuner
Digital TV Tuner
Digital TV Service
FREEVIEW HD
MPEG Profiles and Levels
MPEG4 AVC/H.264
Video Features
Analogue Video Input Signals
NTSC, PAL, SECAM
Input Video Formats
1080p
Teletext
Teletext Memory
2000 pages
Electronic Programme Guide
Digital EPG
Media Player
Supported Video Formats
DivX, DivX HD, DivX Plus HD
SD Memory Card
USB Port
Audio System
Digital Audio Format
Dolby Digital Plus output
Surround Mode
Sound Effects
Speaker System
2 speakers
Output Power / Total
20 Watt
Audio Return Channel (ARC), Automatic Volume Control (AVC), Digital Amplifier
Speakers
2 x main channel speaker - built-in - 10 Watt
Network & Internet Multimedia
Functionality
Digital audio playback, digital photo playback, digital video playback, Internet video playback
Wi-Fi, LAN
Supported Consumer Electronics Control (CEC)
AQUOS LINK
DLNA
Connector Type
4 x HDMI , SCART , Composite video/audio input , Component video input , Headphones , Digital audio output (optical) , VGA input , Serial , Network , USB
USB wireless network adapter
Power supply
Power Consumption Stand by
0.15 Watt
Dimensions & Weight Details
Panel without stand - 186.2 cm x 9.9 cm x 111.2 cm , Panel with stand - 186.2 cm x 43.4 cm x 114.5 cm x 56 kg
Scroll to top
