BT.com
Wishlist
Sharp LC-55CFE6352E 55" 1920x1080 Full HD LED TV
Delivery
Standard Due date unavailable
The Smart F6350 series boasts all the important features expected from a modern TV set. It provides access to the growing application basis, incorporates Miracast and WiDi wireless technologies, as well as wired MHL which charges your smartphone whilst sending multimedia to the Smart TV. Sound system by Harman/Kardon designed to provide a full cinematic audio experience: superb dynamic range, exceptional accuracy with very low distortion, and room-filling sound.
Sharp LC-55CFE6352E Aquos 6350 series - 55" LED TV
LED-backlit LCD TV - Smart TV
Diagonal Class
55"
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Motion Enhancement Technology
Active Motion 400
Video Interface
Component, composite, HDMI, SCART
HDMI Ports Qty
3 ports
Wi-Fi, LAN
PC Interface
VGA (HD-15), HDMI(MHL)
LCD Backlight Technology
LED backlight - D-LED Backlight
Image Aspect Ratio
16:9
TV Tuner
1x analogue, 1x digital
Digital TV Tuner
DVB-C, DVB-S, DVB-S2, DVB-T, DVB-T2
Analogue TV Tuner
PAL, SECAM
Internet Streaming Services
YouTube, Facebook, Twitter
Speaker System
2 speakers
Sound Effects
DTS TruSurround
Stereo Reception System
NICAM, A2
USB
2 ports
Voltage
AC 230V (50 Hz)
Energy Class
Class A+
150 Watt
Power Consumption (On mode)
85 W
Energy Consumption per Year
124 kWh
123.75 cm x 6.86 cm x 72.63 cm
14.4 kg
Energy Class
Class A+
150 Watt
85 W
124 kWh
Diagonal Class
55"
Series
Aquos 6350 series
TV Tuner
Extended PVR
Video Interface
HDMI Ports Qty
3 ports
PC Interface
Dimensions
Without stand
123.75 cm
6.86 cm
72.63 cm
14.4 kg
Display
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Image Aspect Ratio
16:9
Active Motion 400
Dynamic Contrast Ratio
1000000:1
Brightness
300 cd/m²
Time-shift
Stands & Mounts
Stand
Included
Stand Design
Tabletop
Flat Panel Mount Interface
600 x 300 mm
TV Tuner
Analogue TV Tuner
PAL, SECAM
Conditional Access
Common Interface Plus (CI+) slot
Reception System
SECAM-D, SECAM-B, SECAM-K, PAL-B, SECAM-G, PAL-G, PAL-I, PAL-D, SECAM-L, PAL-K
NICAM, A2
Digital TV Tuner
Digital TV Tuner
Digital TV Service
HbbTV
MPEG Profiles and Levels
MPEG4/H.264
Video Features
Analogue Video Input Signals
PAL, SECAM
Electronic Programme Guide
Digital EPG
Media Player
Supported Video Formats
MPEG-4, WMV, ASF, AVI, MKV, VOB, FLV, RM, TS, M2TS, SWF, RMVB, M4V, MPG
Supported Audio Formats
MP3, WMA, AC3, AAC, Ogg Vorbis, LPCM, E-AC3, M4A
Supported Pictures Formats
BMP, JPG, PNG, JPEG
USB Port
USB Ports Qty
2
Audio System
Digital Audio Format
Dolby Digital output, Dolby Digital Plus output, DTS 2.0 digital output
Surround Mode
Sound Effects
DTS TruSurround
Equaliser
Speaker System
2 speakers
Output Power / Total
16 Watt
Audio Return Channel (ARC)
Speakers
2 x main channel speaker - built-in - 8 Watt
Network & Internet Multimedia
Functionality
Digital audio playback, digital photo playback, digital video playback, WEB browsing, Internet video playback
Wi-Fi, LAN
Connect & Share
Intel Wireless Display (WiDi), Wi-Fi Miracast
Application Store
SHARP AQUOS NET+
DLNA
Connector Type
3 x HDMI input , 2 x USB , Network , SCART , Component video input , Composite video/audio input , VGA input , Audio line-in , Audio line-out / headphones , Digital audio output (optical)
CB, ERP, CE/EMC
Power supply
Nominal Voltage
AC 230V (50 Hz)
Power Consumption Stand by
0.5 Watt
Dimensions & Weight Details
Panel without stand - 123.75 cm x 6.86 cm x 72.63 cm x 14.4 kg , Panel with stand - 123.75 cm x 22.24 cm x 75.01 cm x 14.7 kg
Scroll to top
