BT.com
Wishlist
Sharp LC-49CFE6241K 1920 x 1080 HDMI USB HD LED Television
Delivery
Standard Due date unavailable
Whether using the integrated Smart TV functions or connecting to your smart device, it's simple and fun. With 3 HDMI ports, you can connect to your Satellite box, games console, Blu-ray player or any other HDMI equipped device. Its USB port allows you to enjoy your music, movies or photos from a USB memory key.
Sharp LC-49CFE6241K Aquos 624x - 49" LED TV
LED-backlit LCD TV - Smart TV
Diagonal Class
49"
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Motion Enhancement Technology
Active Motion 400
Video Interface
Component, composite, HDMI, SCART
HDMI Ports Qty
3 ports
Wi-Fi, LAN
PC Interface
VGA (HD-15)
HDCP Compatible
LCD Backlight Technology
LED backlight - D-LED Backlight
TV Tuner
1x analogue, 1x digital
Digital TV Tuner
DVB-C, DVB-T, DVB-T2
Analogue TV Tuner
PAL, SECAM
Internet Streaming Services
YouTube, Facebook, Twitter, BBC iPlayer
Speaker System
2 speakers
Sound Effects
DTS TruSurround
Stereo Reception System
NICAM, A2
USB
2 ports
Remote Control
Standard remote
Voltage
AC 230V (50 Hz)
Energy Class
Class A+
110 Watt
Power Consumption (On mode)
67 W
Energy Consumption per Year
98 kWh
109.85 cm x 6.87 cm x 63.33 cm
10.8 kg
Energy Class
Class A+
110 Watt
67 W
98 kWh
Diagonal Class
49"
Series
Aquos 624x
TV Tuner
Extended PVR
Video Interface
HDMI Ports Qty
3 ports
PC Interface
VGA (HD-15)
HDCP Compatible
Dimensions
Without stand
109.85 cm
6.87 cm
63.33 cm
10.8 kg
Display
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Active Motion 400
Dynamic Contrast Ratio
1000000:1
Brightness
300 cd/m²
Advanced Contrast Enhancer circuit (ACE), time-shift
Stands & Mounts
Stand
Included
Stand Design
Tabletop
Flat Panel Mount Interface
600 x 300 mm
TV Tuner
Analogue TV Tuner
PAL, SECAM
Conditional Access
Common Interface Plus (CI+) slot
NICAM, A2
Digital TV Tuner
Digital TV Tuner
Digital TV Service
FREEVIEW HD, HbbTV, SAORVIEW
Video Features
Analogue Video Input Signals
PAL, SECAM
Media Player
Supported Video Formats
MPEG-4, WMV, ASF, AVI, MKV, VOB, FLV, RM, TS, M2TS, SWF, RMVB, M4V, MPG
Supported Audio Formats
MP3, WMA, AC3, AAC, Ogg Vorbis, LPCM, E-AC3, M4A
Supported Pictures Formats
BMP, JPG, PNG, JPEG
USB Port
USB Ports Qty
2
Remote Control
Standard remote
Audio System
Digital Audio Format
Dolby Digital output, DTS digital output, Dolby Digital Plus output
Surround Mode
Sound Effects
DTS TruSurround
Equaliser
Speaker System
2 speakers
Output Power / Total
16 Watt
Audio Return Channel (ARC)
Speakers
2 x main channel speaker - built-in - 8 Watt
Network & Internet Multimedia
Functionality
Digital audio playback, digital photo playback, digital video playback, WEB browsing, Internet video playback, AQUOS Net+
Wi-Fi, LAN
LAN Protocol
Ethernet
Connect & Share
Intel Wireless Display (WiDi), Wi-Fi Miracast
DLNA
Connector Type
3 x HDMI , 2 x USB , Network , SCART , Component video input , Composite video/audio input , VGA input , Audio line-in , Audio line-out / headphones , Digital audio output (optical)
2 AAA batteries
Component video cable , Composite video / audio cable
CB, EMC, CEC, ERP
Power supply
Nominal Voltage
AC 230V (50 Hz)
Power Consumption Stand by
0.5 Watt
Dimensions & Weight Details
Panel without stand - 109.85 cm x 6.87 cm x 63.33 cm x 10.8 kg , Panel with stand - 109.85 cm x 23.17 cm x 66.76 cm x 11.2 kg
Scroll to top
