BT.com
Wishlist
Securifi ALM-BLK-EU Almond 2012 - Router/Range Extender
Delivery
Standard Due date unavailable
Securifi Almond DSL Wi-Fi Ethernet LAN Black ALM-BLK-EU
A Router for Humans
Easy Setup Touchscreen WiFi Router.
You will be online within seconds.
Just connect your Cable/DSL modem and follow the on screen instructions.
Pre-configured security.
Prevent intruders from accessing your wireless data.
Up to 300Mbps using 802.11n MIMO tech.
Connect up to 50 users at a time.
Compatible with older 802.11bg devices.
Everything you need is just a finger tap away.
The user interface is a quantum leap over existing routers.
Securifi Almond - wireless router - 802.11b/g/n - desktop
Wireless router - 2-port switch (integrated)
Enclosure Type
Desktop
Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 GHz
Data Transfer Rate
300 Mbps
MIMO technology
AC 120/230 V
Europe
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz
Data Transfer Rate
300 Mbps
Encryption Algorithm
WPA, WPA2, WEP
MIMO technology
384 MHz
Built-in Devices
2.8-inch touch screen display
WAN: 1 x 10Base-T/100Base-TX - RJ-45 , LAN: 2 x 10Base-T/100Base-TX - RJ-45
External power adapter
AC 120/230 V
1 x network cable
Europe
Scroll to top
