BT.com
Wishlist
Seagate STDE16000200 16TB 4-bay NAS Pro
Delivery
Standard Due date unavailable
Seagate NAS Pro 4-bay is a high-performance network storage solution offering the easiest setup and the industry's most intuitive interface. The NAS Pro 4-bay features hardware, software and Seagate drives designed to work together seamlessly, which reduces your setup time to just a few minutes and delivers reliable performance for years to come. In addition, Seagate runs hours of extensive tests on every NAS Pro 4-bay before it leaves the manufacturing facility, to further ensure the system is running at its best.
The NAS Pro 4-bay runs Seagate NAS OS 4 software, completely designed from the ground up to deliver ease of use, performance, reliability and a flexible platform for running add-on apps, enabling you to do more with your NAS. With the App Manager in NAS OS 4, you can choose to install apps that enhance the functionality of the NAS, such as the surveillance app that turns the NAS into a recording solution for IP cameras or the anti-virus app that can scan files and identify potential threats before it's too late.
Built with the Intel dual-core processor specifically for NAS, ample memory and dual Gigabit Ethernet connections, the NAS Pro 4-bay delivers the performance needed for data-intensive business tasks, such as photo and video editing, accessing large databases, or multiple simultaneous PC/Mac backups. With powerful hardware inside, the NAS Pro 4-bay is a great multi-tasker and can run multiple NAS OS 4 add-on apps simultaneously for increased productivity.
Drives are the core of any high-capacity storage solution and Seagate delivers a specialized drive specifically for NAS systems. Seagate NAS HDD drives, included with the NAS Pro 4-bay, are engineered to run 24 x 7 to deliver the performance needed by various business applications, yet run cooler than other drives on the market. Furthermore, NAS HDD drives are rated for higher reliability than a standard desktop drive, offering more protection for your business's critical files.
Seagate NAS Pro 4-Bay STDE16000200 - NAS server - 16 TB
NAS server
Host Connectivity
Gigabit Ethernet
Total Storage Capacity
16 TB
4 (installed) / 4 (max)
17.4 cm x 21.8 cm x 17 cm
Middle East, Africa, Europe
1 x Intel 1.7 GHz (Dual-Core)
Storage Controller
RAID SATA 3Gb/s - RAID 0, 1, 5, 6, 10, JBOD, 5 hot spare
Hard Drive
4 x 4 TB SATA 3Gb/s
10Mb LAN, 100Mb LAN, GigE
RAM
2 GB
Storage Operating System
Seagate NAS OS 4
Linux, Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Apple MacOS X 10.6 or later, Microsoft Windows Server 2012, Microsoft Windows Vista / XP / 7 / 8
3 years warranty
NAS server
Host Connectivity
Gigabit Ethernet
16 TB
17.4 cm
21.8 cm
17 cm
Built-in Devices
Led panel
Processor / Memory
Processors Installed
1 x Intel 1.7 GHz
Number of Cores
Dual-Core
Max Supported Qty
1
RAM
2 GB DDR3
Storage Controller
RAID
Interface Type
SATA 3Gb/s
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD, RAID 5 hot spare
Hard Drive
HDD - hot-swap
4 x 4 TB
Interface Type
SATA 3Gb/s
Network / Transport Protocol
NTP, iSCSI, SMTP, FTP, DHCP, Bonjour, SMB
Remote Management Protocol
SNMP, HTTP, HTTPS, SSH
Network Services Compatibility
Microsoft Active Directory (AD), Apple Bonjour Protocol, DHCP, DFS, Microsoft CIFS, Network File System (NFS), FTP, FTPS, Server Message Block (SMB), Apple File Protocol (AFP), HTTP, HTTPS, Web-based Distributed Authoring and Versioning (WebDAV)
Dynamic DNS server, print server, IPv6 support, DFS support, SSH support, Jumbo Frames support, IPv4 support, Apple Time Machine compatible, WebDAV server, SNMP support, Precision Time Protocol (PTP)
UPnP
Expansion Bays
4 (total) / 0 (free) x hot-swap - 2.5" / 3.5"
2 x USB 3.0 , 1 x USB 2.0 , 2 x Ethernet 1000
1 x network cable
Security lock slot (cable lock sold separately), UPS support
External power adapter
Power Provided
120 Watt
Seagate NAS OS 4
Limited warranty - 3 years
0 - 80% (non-condensing)
Scroll to top
