BT.com
Wishlist
Seagate STDD4000200 4TB 2-bay NAS Pro
Delivery
Standard Due date unavailable
Seagate NAS Pro 2-bay is a high-performance network storage solution offering the easiest setup and the industry's most intuitive interface. The NAS Pro 2-bay features hardware, software and Seagate drives designed to work together seamlessly, which reduces your setup time to just a few minutes and delivers reliable performance for years to come. In addition, Seagate runs hours of extensive tests on every NAS Pro 2-bay before it leaves the manufacturing facility, to further ensure the system is running at its best. The NAS Pro 2-bay runs Seagate NAS OS 4 software, completely designed from the ground up to deliver ease of use, performance, reliability and a flexible platform for running add-on apps, enabling you to do more with your NAS. With the App Manager in NAS OS 4, you can choose to install apps that enhance the functionality of the NAS, such as the surveillance app that turns the NAS into a recording solution for IP cameras or the anti-virus app that can scan files and identify potential threats before it's too late. Built with the powerful processor specifically for NAS, ample memory and dual Gigabit Ethernet connections, the NAS Pro 2-bay delivers the performance needed for data-intensive business tasks, such as photo and video editing, accessing large databases, or multiple simultaneous PC/Mac backups. With powerful hardware inside, the NAS Pro 2-bay is a great multi-tasker and can run multiple NAS OS 4 add-on apps simultaneously for increased productivity. Drives are the core of any high-capacity storage solution and Seagate delivers a specialized drive specifically for NAS systems. Seagate NAS HDD drives, included with the NAS Pro 2-bay, are engineered to run 24×7 to deliver the performance needed by various business applications, yet run cooler than other drives on the market. Furthermore, NAS HDD drives are rated for higher reliability than a standard desktop drive, offering more protection for your business's critical files.
Seagate Business Storage STDD4000200 - NAS server - 4 TB
NAS server
Host Connectivity
Gigabit Ethernet
Total Storage Capacity
4 TB
2 (installed) / 2 (max)
12 cm x 21.8 cm x 17 cm
1.75 kg
1 x Intel 1.7 GHz (Dual-Core)
Storage Controller
RAID SATA 3Gb/s - RAID 0, 1, JBOD
Hard Drive
2 x 2 TB SATA 3Gb/s - One-Touch Backup
10Mb LAN, 100Mb LAN, GigE
RAM
2 GB
UNIX, Linux, Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Apple MacOS X 10.6 or later, Microsoft Windows Server 2012, Microsoft Windows Vista / XP / 7 / 8
3 years warranty
NAS server
Host Connectivity
Gigabit Ethernet
4 TB
12 cm
21.8 cm
17 cm
1.75 kg
Built-in Devices
LED lamp
Processor / Memory
Processors Installed
1 x Intel 1.7 GHz
Number of Cores
Dual-Core
Max Supported Qty
1
RAM
2 GB DDR3
Storage Controller
RAID
Interface Type
SATA 3Gb/s
RAID Level
RAID 0, RAID 1, JBOD
Hard Drive
HDD - hot-swap - 3.5"
2 x 2 TB
Interface Type
SATA 3Gb/s
One-Touch Backup
Network / Transport Protocol
NTP, iSCSI, SMTP, FTP, DHCP, Bonjour, SMB
Remote Management Protocol
SNMP, HTTP, SSH
Network Services Compatibility
DHCP, DFS, Microsoft CIFS, Network File System (NFS), FTP, Apple File Protocol (AFP), HTTP
Wake on LAN (WOL), dynamic DNS server, IPv6 support, SSH support, static IP mode, IPv4 support, DLNA Media Server, WebDAV server, link aggregation trunking, SFTP server, Precision Time Protocol (PTP)
UPnP
Expansion Bays
2 (total) / 0 (free) x hot-swap - 3.5"
2 x USB 3.0 , 1 x USB 2.0 , 2 x Ethernet 1000Base-TX - RJ-45
1 x network cable
K-lock security slot, Mobile Transfer Protocol (MTP)
IPv6 Ready
External power adapter
Power Provided
60 Watt
Limited warranty - 3 years
0 - 80% (non-condensing)
Scroll to top
