BT.com
Wishlist
Seagate STCT2000200 2TB 2-bay NAS
Delivery
Standard Due date unavailable
Seagate NAS 2-bay is a full-featured network storage solution offering the easiest setup and the industry's most intuitive interface. The NAS 2-bay features hardware, software and Seagate drives designed to work together seamlessly, which reduces your setup time to just a few minutes and delivers reliable performance for years to come. In addition, Seagate runs hours of extensive tests on every NAS 2-bay before it leaves manufacturing facility, to further ensure the system is running at its best.
The NAS 2-bay runs Seagate NAS OS 4 software, completely designed from the ground up to deliver ease of use, performance, reliability and a flexible platform for running add-on apps, enabling you to do more with your NAS.
Drives are the core of any high-capacity storage solution and Seagate delivers a specialized drive specifically for NAS systems. Seagate NAS HDD drives, included with the NAS 2-bay, are engineered to run 24×7 to deliver the performance needed by various business applications, yet run cooler than other drives on the market. Furthermore, NAS HDD drives are rated for higher reliability than a standard desktop drive, offering more protection for your business's critical files.
Seagate Business Storage STCT2000200 - NAS server - 2 TB
NAS server
Host Connectivity
Gigabit Ethernet
Total Storage Capacity
2 TB
1 (installed) / 2 (max)
12 cm x 21.8 cm x 17 cm
1.7 kg
1 x ARM 1.2 GHz
Storage Controller
RAID SATA 3Gb/s - RAID 0, 1, JBOD
Hard Drive
1 x 2 TB SATA 3Gb/s - One-Touch Backup
10Mb LAN, 100Mb LAN, GigE
RAM
512 MB
UNIX, Linux, Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Apple MacOS X 10.6 or later, Microsoft Windows Server 2012, Microsoft Windows Vista / XP / 7 / 8
3 years warranty
NAS server
Host Connectivity
Gigabit Ethernet
2 TB
12 cm
21.8 cm
17 cm
1.7 kg
Processor / Memory
Processors Installed
1 x ARM 1.2 GHz
Max Supported Qty
1
RAM
512 MB DDR3
Storage Controller
RAID
Interface Type
SATA 3Gb/s
RAID Level
RAID 0, RAID 1, JBOD
Hard Drive
HDD - hot-swap - 3.5"
1 x 2 TB
Interface Type
SATA 3Gb/s
One-Touch Backup
S.M.A.R.T., 256-bit AES
Network / Transport Protocol
NTP, iSCSI, SMTP, FTP, DHCP, Bonjour, SMB
Remote Management Protocol
SNMP, HTTP, SSH
Network Services Compatibility
DHCP, DFS, Microsoft CIFS, Network File System (NFS), FTP, Apple File Protocol (AFP), HTTP
Wake on LAN (WOL), dynamic DNS server, IPv6 support, SSH support, static IP mode, IPv4 support, DLNA Media Server, WebDAV server, link aggregation trunking, SFTP server, Precision Time Protocol (PTP)
Encryption Algorithm
256-bit AES
UPnP
Expansion Bays
2 (total) / 1 (free) x hot-swap - 3.5"
2 x USB 3.0 , 1 x Ethernet 1000Base-TX - RJ-45
1 x network cable
K-lock security slot, Mobile Transfer Protocol (MTP)
IPv6 Ready
External power adapter
Power Provided
48 Watt
Limited warranty - 3 years
0 - 80% (non-condensing)
Scroll to top
