BT.com
Wishlist
Seagate Savvio 10K.6 300GB 2.5" 10000rpm SAS Hard Drive
Delivery
Standard Due date unavailable
The Seagate Enterprise Performance 10K HDD delivers mission critical performance with TurboBoost, high capacities and the low power that data centers need.
Make the transition from standard 3.5-inch form factor drives with limited capacities and slower performance to the larger, faster and best-in-class Enterprise Performance 10K HDD. With 2x the capacity and a 70% smaller footprint, data centers can store and access data faster than ever, enabling them to keep pace with data growth while optimizing scarce IT real estate.
Enterprise Performance 10K HDD advanced media management technology improves drive reliability and data integrity. This eighth generation hard drive lets you rest easier knowing your storage devices will perform as expected. This enterprise hard drive features the Seagate RAID Rebuild technology, making RAID recovery faster and safer.
Seagate Enterprise Performance 10K drives are offered in a self-encrypting drive option and can be used as normal drives or as part of a more secure solution at no extra cost.
Seagate Enterprise Performance 10K HDD ST300MM0026 - hard drive - 300 GB - SAS 6Gb/s
Hard drive - internal
300 GB
Hardware Encryption
2.5" SFF
SAS 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
64 MB
Spindle Speed
10000 rpm
PowerChoice, Protection Information (PI), Seagate Instant Secure Erase (ISE)
7.01 cm x 10.045 cm x 1.5 cm
217 g
Microsoft Certification
Compatible with Windows 7
5 years warranty
300 GB
Hardware Encryption
2.5" SFF
SAS 6Gb/s
Buffer Size
64 MB
7.01 cm
10.045 cm
1.5 cm
217 g
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
204 MBps
Average Latency
2.9 ms
Spindle Speed
10000 rpm
Reliability
Non-Recoverable Errors
1 per 10^16
Expansion & Connectivity
1 x SAS 6Gb/s
Compatible Bay
2.5" SFF
Limited warranty - 5 years
5 °C
55 °C
Shock Tolerance
40 g @ 11ms half-sine pulse (operating) / 400 g @ 2ms half-sine pulse (non-operating)
Scroll to top
