BT.com
Wishlist
Seagate Exos 6TB E-Class Nearline Enterprise 7200RPM 3.5" 256MB Hard Drive
Seagate Exos 6TB E-Class Nearline...
£215.14
More than 50 in stock
£215.14
Add to wishlist
Delivery
Standard 1-3 working days
Supporting the industry's best response times for an 8TB nearline drive, Seagate's Enterprise Capacity 3.5 HDD enables the fastest data transfers thanks to our comprehensive advanced caching technology. When building maximum density server and storage solutions with Seagate's Enterprise Capacity 3.5 HDD, you can rest easy knowing that your storage infrastructure can scale to meet your growing capacity needs while offering your users a consistent and predictable response rate.
What's in the box
  • Seagate Enterprise Capacity 3.5 HDD V.5 ST6000NM0115 - hard drive
  • Software
Seagate Exos 7E8 ST6000NM0115 - hard drive - 6 TB - SATA 6Gb/s
Hard drive - internal
6 TB
3.5" x 1/3H
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
256 MB
Spindle Speed
7200 rpm
Halogen Free, Ramp Load, dual processor, PowerChoice, Humidity Sensor, advanced format 512e, 24x7 availability, Advanced Write Caching
101.85 mm x 147 mm x 26.1 mm
705 g
5 years warranty
6 TB
3.5" x 1/3H
SATA 6Gb/s
Buffer Size
256 MB
Bytes per Sector
512
101.85 mm
147 mm
26.1 mm
705 g
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
226 MBps
Average Latency
4.16 ms
Spindle Speed
7200 rpm
Reliability
MTBF
2,000,000 hours
24x7 Operation
Non-Recoverable Errors
1 per 10^15
Expansion & Connectivity
1 x SATA 6 Gb/s
Compatible Bay
3.5" x 1/3H
Power Consumption
7.25 Watt (idle) , 8.31 Watt (active)
Software Included
Seagate SeaTools
Limited warranty - 5 years
5 °C
60 °C
Shock Tolerance (operating)
40 g @ 2 ms
Shock Tolerance (non-operating)
250 g @ 1 ms
Scroll to top
