BT.com
Wishlist
Seagate Enterprise Performance 10K HDD ST1200MM0118 Hard Drive 1.2TB
Delivery
Standard Due date unavailable
The Seagate Enterprise Performance 10K HDD is an ideal 1.2 TB hard drive for mission critical applications. It delivers best-in-class mission critical random performance, highest capacities and the low power that data centers need to meet demanding service level agreements and to keep up with data growth and reduce IT operating costs.
Seagate Enterprise Performance 10K HDD ST1200MM0118 - hard drive - 1.2 TB - SAS 12Gb/s
Hard drive - internal
1.2 TB
NAND Flash Memory Type
Enterprise multi-level cell (eMLC)
2.5" SFF
SAS 12Gb/s
Data Transfer Rate
1.2 GBps
Buffer Size
128 MB
Spindle Speed
10000 rpm
PowerChoice, Protection Information (PI), Seagate RAID Rebuild, Seagate TurboBoost, S.M.A.R.T.
70.1 mm x 100.45 mm x 15 mm
193 g
5 years warranty
1.2 TB
2.5" SFF
SAS 12Gb/s
Buffer Size
128 MB
Bytes per Sector
4096
70.1 mm
100.45 mm
15 mm
193 g
Performance
Drive Transfer Rate
1.2 GBps (external)
Internal Data Rate
241 MBps
Average Latency
2.9 ms
Spindle Speed
10000 rpm
Reliability
MTBF
2,000,000 hours
Non-Recoverable Errors
1 per 10^16
Expansion & Connectivity
1 x SAS 12 Gb/s
Compatible Bay
2.5" SFF
Power Consumption
4.26 Watt (idle) , 7.25 Watt (active)
Limited warranty - 5 years
5 °C
55 °C
Shock Tolerance (operating)
40 g @ 11 ms
Shock Tolerance (non-operating)
400 g @ 2 ms
Scroll to top
