BT.com
Wishlist
Seagate Enterprise NAS HDD Hard drive 6 TB Internal 3.5" SATA 6Gb/s
Seagate Enterprise NAS HDD Hard...
£288.87
10 in stock
£288.87
Add to wishlist
Delivery
Standard 1-3 working days
The Seagate Enterprise NAS HDD is designed to combine up to 6TB of industry-leading capacity with reliability and performance. Designed for mid-range enterprise and private cloud environments, this NAS HDD delivers sustained performance for global availability and 24/7 accessibility.
Seagate Enterprise NAS HDD ST6000VN0001 - hard drive - 6 TB - SATA 6Gb/s
Hard drive - internal
6 TB
3.5" x 1/3H
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
128 MB
Spindle Speed
7200 rpm
Dual Stage Actuator (DSA), Seagate AcuTrac technology, Seagate RAID Rebuild, Humidity Sensor, Low Halogen, Super Parity, Hot-Plug Support, Power Balance technology
101.85 mm x 147 mm x 26.1 mm
780 g
5 years warranty
6 TB
3.5" x 1/3H
SATA 6Gb/s
Buffer Size
128 MB
Bytes per Sector
512
101.85 mm
147 mm
26.1 mm
780 g
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
216 MBps
Average Latency
4.16 ms
Spindle Speed
7200 rpm
Reliability
MTBF
1,200,000 hours
Non-Recoverable Errors
1 per 10^15
Expansion & Connectivity
1 x SATA 6 Gb/s
Compatible Bay
3.5" x 1/3H
Power Consumption
11.27 Watt (read) , 6.9 Watt (idle)
5 years warranty
Limited warranty - 5 years
60 °C
Vibration Tolerance (non-operating)
5 g @ 10-500 Hz
Seagate Enterprise NAS HDD Hard drive 6 TB Internal...
£288.87
Save on this ideal PC Build kit!
Save £10.36
£308.42
Cables - Cables
£288.87
Save 50% On This 1m SATA Cable When Bought With This Item
Save £3.60
£292.47
Scroll to top
