BT.com
Wishlist
Seagate Enterprise Capacity Hard drive 2TB Internal 3.5" SATA 6Gb/s 7200rpm buffer: 128 MB
Delivery
Standard Due date unavailable
The Seagate Enterprise Capacity 3.5 HDD delivers high capacity without sacrificing performance for reliable access to bulk storage of unstructured data.
Seagate Enterprise Capacity 3.5 HDD V.4 ST2000NM0024 - hard drive - 2 TB - SATA 6Gb/s
Hard drive - internal
2 TB
3.5" x 1/3H
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
128 MB
Spindle Speed
7200 rpm
Enhanced Error Correction Code, Ramp Load, dual processor, PowerChoice
101.85 mm x 147 mm x 26.1 mm
605 g
Microsoft Certification
Compatible with Windows 7
5 years warranty
2 TB
3.5" x 1/3H
SATA 6Gb/s
Buffer Size
128 MB
Bytes per Sector
512
101.85 mm
147 mm
26.1 mm
605 g
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
216 MBps
Average Latency
4.16 ms
Spindle Speed
7200 rpm
Reliability
MTBF
1,400,000 hours
Non-Recoverable Errors
1 per 10^15
Expansion & Connectivity
1 x SATA 6 Gb/s
Compatible Bay
3.5" x 1/3H
Power Consumption
4.5 Watt (idle) , 8.08 Watt (active)
Limited warranty - 5 years
5 °C
60 °C
Shock Tolerance
70 g @ 2ms (operating) / 300 g @ 1ms (non-operating)
Vibration Tolerance
5 g @ 10-500 Hz (non-operating)
Scroll to top
