BT.com
Wishlist
Seagate Enterprise Capacity 3.5 HDD ST8000NM0075 Hard Drive 8TB
Seagate Enterprise Capacity 3.5 HDD...
£294.74
£294.74
Add to wishlist
Delivery
Standard 1-3 working days
Supporting the industry's best response times for an 8TB a nearline drive, the Seagate Enterprise Capacity 3.5 HDD enables the fastest data transfers thanks to comprehensive advanced caching technology. Meet your storage workload requirements in the most efficient and cost-effective data center footprint available on the market. With innovative technology advancements like PowerBalance, PowerChoice and RAID Rebuild, you can customize your bulk storage requirements for even greater improvements in your TCO.
Seagate Enterprise Capacity 3.5 HDD ST8000NM0075 - hard drive - 8 TB - SAS 12Gb/s
Hard drive - internal
8 TB
3.5" x 1/3H
SAS 12Gb/s
Data Transfer Rate
1.2 GBps
Buffer Size
256 MB
Spindle Speed
7200 rpm
PowerChoice, T10 Protection Information (T10 PI), Seagate RAID Rebuild, Dual Port, Humidity Sensor, Low Halogen, Super Parity, Power Balance technology, advanced format 512e, 24x7 availability
101.85 mm x 147 mm x 26.1 mm
780 g
Microsoft Certification
Compatible with Windows 7
5 years warranty
8 TB
3.5" x 1/3H
SAS 12Gb/s
Buffer Size
256 MB
Bytes per Sector
512
101.85 mm
147 mm
26.1 mm
780 g
Performance
Drive Transfer Rate
1.2 GBps (external)
Internal Data Rate
237 MBps
Average Latency
4.16 ms
Spindle Speed
7200 rpm
Reliability
MTBF
2,000,000 hours
24x7 Operation
Non-Recoverable Errors
1 per 10^15
Expansion & Connectivity
2 x SAS 12 Gb/s
Compatible Bay
3.5" x 1/3H
Power Consumption
9 Watt (idle) , 10 Watt (read)
Limited warranty - 5 years
5 °C
60 °C
Shock Tolerance (operating)
70 g @ 2 ms
Shock Tolerance (non-operating)
300 g @ 2 ms
Vibration Tolerance (non-operating)
4.9 g @ 10-500 Hz
Scroll to top
