BT.com
Wishlist
Seagate Enterprise Capacity 2.5 HDD ST1000NX0323 - Hard Drive 1TB
Delivery
Standard Due date unavailable
The Seagate Enterprise Capacity 2.5 HDD is the only 2.5-inch enterprise-class hard drive delivering both, capacities and enterprise reliability at the industry's lowest power per Watt for storage-hungry near-line applications.
Seagate Enterprise Capacity 2.5 HDD ST1000NX0323 - hard drive - 1 TB - SAS 12Gb/s
Hard drive - internal - nearline
1 TB
2.5" SFF
SAS 12Gb/s
Data Transfer Rate
1.2 GBps
Buffer Size
128 MB
Spindle Speed
7200 rpm
PowerChoice, Secure Drive, Seagate RAID Rebuild, Low Halogen
70.1 mm x 100.45 mm x 15 mm
190 g
5 years warranty
1 TB
2.5" SFF
SAS 12Gb/s
Buffer Size
128 MB
Bytes per Sector
4096
70.1 mm
100.45 mm
15 mm
190 g
Performance
Drive Transfer Rate
1.2 GBps (external)
Internal Data Rate
136 MBps
Average Latency
4.16 ms
Spindle Speed
7200 rpm
Reliability
MTBF
1,400,000 hours
Non-Recoverable Errors
1 per 10^15
Expansion & Connectivity
2 x SAS 12 Gb/s
Compatible Bay
2.5" SFF
Power Consumption
3.29 Watt (idle) , 5.9 Watt (read) , 1.52 Watt (standby)
Limited warranty - 5 years
5 °C
55 °C
Shock Tolerance (operating)
25 g @ 2 ms
Shock Tolerance (non-operating)
400 g @ 2 ms
Vibration Tolerance (operating)
0.5 g @ 5-500 Hz
Vibration Tolerance (non-operating)
3 g @ 5-500 Hz
Scroll to top
