BT.com
Wishlist
Seagate Cheetah 15K.7 600GB 3.5IN 15K RPM 16MB SAS2
Seagate Cheetah 15K.7 600GB 3.5IN...
£277.32
Hurry, only 3 left in stock!
£277.32
Add to wishlist
Delivery
Standard 1-3 working days
Seventh-generation Seagate Cheetah 15K.7 drive is the fastest, highest capacity and most reliable ever. Lower watts/GB ratio helps achieve reduced power and cooling costs while optimizing capacity requirements. Seagate continues to focus on reliability and data protection. MTBF is an industry-leading 1.6 million hours. Seagate-exclusive enhanced error correction code better maintains performance throughout the life of the drive and reduces the probability of lost data. The third generation of Seagate-exclusive background media scan proactively scans the media for potential defects during drive idle time. It enables incipient errors to be corrected before data is lost. Quick and robust download feature loads firmware in seconds, with built-in protection to ensure no corruption in the event of a power failure during firmware switch.
Seagate Cheetah 15K ST3600057SS - hard drive - 600 GB - SAS 6Gb/s
Hard drive - internal
600 GB
3.5" x 1/3H
SAS 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
16 MB
Spindle Speed
15000 rpm
Enhanced Error Correction Code, Background Media Scan (BMS), PowerTrim technology, Perpendicular Magnetic Recording (PMR)
10.2 cm x 14.7 cm x 2.5 cm
0.69 kg
Microsoft Certification
Compatible with Windows 7
5 years warranty
600 GB
3.5" x 1/3H
SAS 6Gb/s
Buffer Size
16 MB
10.2 cm
14.7 cm
2.5 cm
0.69 kg
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
296 MBps
Seek Time
3.4 ms (average)
Track-to-Track Seek Time
0.2 ms
Average Latency
2 ms
Spindle Speed
15000 rpm
Reliability
MTBF
1,600,000 hours
Non-Recoverable Errors
1 per 10^16
Expansion & Connectivity
1 x SAS 6Gb/s
Compatible Bay
3.5" x 1/3H
5 years warranty
Limited warranty - 5 years
5 °C
55 °C
Shock Tolerance
60 g @ 2ms (operating) / 300 g @ 2ms (non-operating)
Vibration Tolerance
1 g @ 5-400 Hz (operating) / 3 g @ 5-400 Hz (non-operating)
£277.32
Save on this ideal PC Build kit!
Save £10.36
£296.87
Scroll to top
