BT.com
Wishlist
Seagate Archive Hard drive 8TB Internal 3.5" SATA 6Gb/s
Delivery
Standard Due date unavailable
Industry's first high-capacity hard drive is designed for cost-effectively storing active archive data and cloud content.
Lowest cost/TB online data archive solution for petabytes of growing archival storage helps to ensure affordable long-term data management. SMR-enabled technology ensures efficient and economical cold storage operations even in the harshest data center environments.
The Archive HDD is optimized for cold data storage with the lowest power consumption and the on-demand, time-to-ready PowerChoice feature.
What's in the box
  • Seagate Archive HDD ST8000AS0002 - hard drive
  • Software
Seagate Archive HDD ST8000AS0002 - hard drive - 8 TB - SATA 6Gb/s
Hard drive - internal
8 TB
3.5" x 1/3H
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
128 MB
Native Command Queuing (NCQ), Halogen Free, Advanced Format technology, PowerChoice, Seagate AcuTrac technology, S.M.A.R.T.
101.6 mm x 146.99 mm x 26.11 mm
780 g
3 years warranty
8 TB
3.5" x 1/3H
SATA 6Gb/s
Buffer Size
128 MB
Bytes per Sector
4096
101.6 mm
146.99 mm
26.11 mm
780 g
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
190 MBps (read) / 150 MBps (write)
Reliability
MTBF
800,000 hours
Non-Recoverable Errors
1 per 10^14
Load / Unload Cycles
300,000
Expansion & Connectivity
1 x SATA 6 Gb/s
Compatible Bay
3.5" x 1/3H
Power Consumption
7.5 Watt (active) , 5 Watt (idle) , 1 Watt (standby) , 1 Watt (sleep)
Software Included
Seagate SeaTools
RoHS
Limited warranty - 3 years
60 °C
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
5* Second part of the review
Reviewed by Anonymous on 10/08/2015
I wanted to even out the ratings of the review because the replacement drives which BT sent me performed perfectly. It took a bit of time for the replacement drives to reach me, but I suspect that BT took some care to make sure that I was a satisfied customer and that I was not going to be saddled with two more lemons. I have had the drives running 24/7 for well over a week now and they are flawless. I might well have been unlucky, or it might well be that BT cares enough about customer support to make sure that I was not left disappointed a second time. Either way, BT wins and Seagate ends up from both of my reviews as a 2.5 I am really happy with the drives and REALLY HAPPY with BT.
1* This is a two part review - please read
Reviewed by Anonymous on 22/07/2015
I was mightily disappointed by Seagate and massively impressed by BT so this review will centre on BT. I ordered two of these drives and both were DOA on arrival - this is not BT's fault. I have been buying Seagate drives (from BT mainly) for the past 15 years. I phoned up BT to have the drives replaced and they offered to have them collected. I am an invalid so I was happy about the offer. I sent a friend of mine to get money out of my bank and made sure I had change to pay for the postage. I was gobsmacked when the person from Parcelforce told me that the postage had been paid (by BT). You know who your friends are when things go wrong and BT has been exemplary in this regard. I had tested the drives on an A58, X58, Z87 and Z97 based systems and they were not recognised. They were dead. I explained the trouble-shooting I'd done and BT din't faff me off or mess me about. It was all about how to get the drives replaced with the least hassle to me. --HD, +++BT
Scroll to top
