Click to visit BT.com
BT.com
Wishlist
Seagate 500GB GoFlex USB 3.0 2.5" Portable Hard Drive Red
Quicklinx: 7MR0WS00
Mfr#: STAA500208
The GoFlex® ultra-portable drive features a sleek and highly flexible design that helps you back up, encrypt, store and access your files easily anytime, anywhere.
As a highly upgradable portable hard drive, and the core of the Seagate GoFlex Storage System, the Seagate STAA500208 GoFlex Ultra-Portable USB 3.0 Hard Drive gives you the flexibility you need to extend your digital life wherever you go. Furthermore, with a Seagate GoFlex Ultra-Portable USB 3.0 Hard Drive it is easy to manage your backup schedules, encrypt your files and view your drive's statistics.
Key Features
  • Stylish Red design and 500GB Storage Capacity
  • Features USB 2.0 or 3.0 plug-and-play connectivity
  • Includes preloaded easy-to-use backup software
  • Lets you upgrade to USB 3.0, FireWire 800 or eSATA
  • Ensures automatic continuous backup of your data
  • Secures your backed up files and protects your privacy with powerful encryption software
  • Includes the Seagate Dashboard management
The Seagate STAA500208 GoFlex 500GB USB 3.0 Hard Drive Stores
  • Up to 142,500 digital photos
  • Up to 125,000 songs (MP3)
  • Up to 12,300 songs (uncompressed CD quality)
  • Up to 36 hours of Digital Video (DV)
  • Up to 220 hours of DVD quality video
  • Up to 60 hours of HD video
Examples of the number of photos, songs, videos and any other files that can be stored on a hard drive are provided for illustrative purposes only. Your results will vary based on file size and format, settings, features, software and other factors.) One gigabyte (GB) = one billion bytes. One terabyte (TB) = one trillion bytes. Total accessible capacity varies depending on operating environment.
Works interchangeably with PCs and Macs
Whether you have a PC or a Mac, or both, you can access and save files on the same GoFlex ultra-portable drive.* The drive must be reformatted to HFS+ in order to use backup software for Mac or Time Machine software
Automatic backups Always secure
Your GoFlex ultra-portable drive comes preloaded with easy-to-use software that helps you manage your backup schedules, encrypt your files, and view your drive's statistics.
Box Contains
  • GoFlex ultra-portable drive
  • Preloaded backup software with encryption
  • GoFlex USB 2.0 or 3.0 interface adapter
  • 18-inch USB 2.0 or 3.0 cable
  • Quick Start Guide
Seagate FreeAgent GoFlex - hard drive - 500 GB - USB 3.0
Hard drive - external ( portable )
500 GB
USB 3.0
Data Transfer Rate
5.0 Gbps (USB 3.0)
192-bit Triple DES
Power Source
USB bus
Enclosure Colour
Red
8.3 cm x 11.1 cm x 1.4 cm
150 g
Microsoft Certification
Compatible with Windows 7
3 years warranty
500 GB
USB 3.0
192-bit Triple DES
8.3 cm
11.1 cm
1.4 cm
150 g
Performance
Interface Transfer Rate
5.0 Gbps (USB 3.0)
Expansion & Connectivity
1 x USB 3.0
Power Source
USB bus
Software Included
Drivers & Utilities
Microsoft Windows Vista / XP / 7, Apple MacOS X 10.4.9 or later
USB adapter
1 x USB cable - 46 cm
Enclosure Colour
Red
3 years warranty
Service & Support Details
Limited warranty - 3 years
