Click to visit BT.com
BT.com
Wishlist
Seagate 500GB Expansion USB 3.0 2.5" Portable Drive
4.5*
Quicklinx: 84C4WS00
Mfr#: STBX500200
Seagate Expansion portable drive, add-on storage for your PC
The Seagate® Expansion portable drive is compact and perfect for on-the-go. Instantly add more storage space to your computer and take large files with you when you travel. Setup is simple and straightforward; simply connect a single USB cable and you are ready to go. The drive is powered from the USB cable, so there is no need for an external power supply. Plus, it is automatically recognized by the Windows® operating system, so there is no software to install and nothing to configure. Saving files is easy--simply drag-and-drop.
Take advantage of the fast data transfer speeds with the USB 3.0 interface by connecting to a SuperSpeed USB 3.0 port. USB 3.0 is backwards compatible with USB 2.0 for additional system compatibility.
  • Windows® 7, Windows Vista®, Windows XP SP3 (32-bit and 64-bit) operating system
  • SuperSpeed USB 3.0 port (required for USB 3.0 transfer speeds or backwards compatible with USB 2.0 ports at USB 2.0 transfer speeds)1
Inside the Box
  • Seagate Expansion drive
  • 4-foot (120cm) USB 3.0 cable
  • 2-year limited warranty (EMEA)
  • Quick start guide
Seagate Expansion Portable Drive - hard drive - 500 GB - USB 3.0
Hard drive - external ( portable )
500 GB
USB 3.0
8.11 cm x 12.23 cm x 1.55 cm
170 g
EMEA
Microsoft Certification
Compatible with Windows 7
2 years warranty
500 GB
USB 3.0
8.11 cm
12.23 cm
1.55 cm
170 g
Expansion & Connectivity
1 x USB 3.0
Microsoft Windows XP SP3, Microsoft Windows Vista / 7
1 x USB 3.0 cable - 45.72 cm
EMEA
Resources
The following resources are available for the Seagate 500GB Expansion USB 3.0 2.5" Portable Drive
Customer reviews
Write a review for the Seagate 500GB Expansion USB 3.0 2.5" Portable Drive here!
Seagate External Drive 500Gb
Reviewed by Driffter. Review Posted 12/08/2014
On my second unit now, just plug and play I use them on my Humax Recoder it can store 180 films with ease, I always leave about 12% free. Comes with USB lead and emits no noise whilst in use. Also have the 1TB and is the same in every way, storage 360 plus films with space to spare. Highly recommended.
  • Overall 5*
  • Ease of use 5*
  • Value for money 5*
seagate
Reviewed by danny rylance. Review Posted 18/05/2013
good value for money
  • Overall 4*
  • Ease of use 4*
  • Value for money 4*
The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
