Click to visit BT.com
BT.com
Wishlist
Seagate 500GB Barracuda SATA-600 7200RPM 16MB 3.5" Hard Drive
5.0*
Quicklinx: 7M3CWS00
Mfr#: ST500DM002
Form Factor: 3.5" x 1/3H
Type: Hard drive
Interface Type: Serial ATA-600
Capacity: 500GB
Spin Speed (rpm): 7200rpm
Express delivery Order within the next 23 hours for delivery on Friday
41 in stock
£42.54
Essential accessories
The Seagate Desktop HDD is the one drive for every desktop system need, reliability and simplicity. Now available in capacities 500 MB. Count on Seagate to deliver the storage innovations that bring down your costs and crank up your storage.
Seagate Desktop HDDs with 500 MB-per-disk have advanced power modes to save more energy while in idle states - without sacrificing performance. Desktop HDDs are produced using the most sophisticated manufacturing process in the industry, with a focus on environmental stewardship.
Seagate Desktop HDD ST500DM002 - hard drive - 500 GB - SATA 6Gb/s
Hard drive - internal
500 GB
3.5" x 1/3H
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
16 MB
Native Command Queuing (NCQ), Perpendicular Magnetic Recording (PMR)
101.6 mm x 146.99 mm x 19.98 mm
415 g
Microsoft Certification
Compatible with Windows 7
2 years warranty
500 GB
3.5" x 1/3H
SATA 6Gb/s
Buffer Size
16 MB
Bytes per Sector
512
101.6 mm
146.99 mm
19.98 mm
415 g
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
144 MBps (read) / 125 MBps (write)
Reliability
Non-Recoverable Errors
1 per 10^14
Expansion & Connectivity
1 x SATA 6 Gb/s - 7 pin Serial ATA
Compatible Bays
1 x 3.5" x 1/3H - internal
RoHS
60 °C
Seagate 500GB Barracuda SATA-600 7200RPM 16MB 3.5 Bundle deal on Seagate 500GB Barracuda SATA-600 7200RPM 16MB 3.5" Hard Drive
Including:
CoolerMaster High Performance Thermal Paste 2g CoolerMaster High Performance Thermal Paste 2g worth £4.83 | in stock
Akasa Cable Tidy Kit Akasa Cable Tidy Kit worth £4.20 | in stock
StarTech.com 7 Piece Precision Screwdriver Computer Tool Kit StarTech.com 7 Piece Precision Screwdriver Computer Tool Kit worth £11.61 | in stock
Best Value Duratool Antistatic Wrist Band Best Value Duratool Antistatic Wrist Band worth £3.60 | while stocks last
C2G 1m 7-pin 180° to 90° 1-Device Serial ATA Cable C2G 1m 7-pin 180° to 90° 1-Device Serial ATA Cable worth £3.58 | in stock
£62.07
saving £8.26
Cables (1)
Cables
Including:
£44.32
saving £1.78
Other bundles (2)
Including:
£44.34
saving £1.80
Including:
Intenso 32GB Rainbow Transparent USB Flash Drive Intenso 32GB Rainbow Transparent USB Flash Drive worth £5.48 | in stock
£46.63
saving £1.39
Customer reviews
Write a review for the Seagate 500GB Barracuda SATA-600 7200RPM 16MB 3.5" Hard Drive here!
Excellent HDD
Reviewed by Gary Mason. Review Posted 18/02/2012
I have been buying Seagate drives for 15+ years and have only ever had one fail but it was 3 1/2yrs old they are generally excellent drives this is my second Seagate 500GB Barracuda the previous drive I put into my Sky+HD box which also works a treat. Im only giving it 4 stars for value for money as I feel in general HDD's are still a bit over price. Performance wise you can't go to wrong.
  • Overall 5*
  • Ease of use 5*
  • Value for money 4*
Seagate 500GB - overall a good buy.
Reviewed by Anonymous Review Posted 05/12/2013
Have used Seagate/Maxtor for 2 decades without any problems so I stick with this make. This disk is one from the latest Seagate range and represents good cash/bytes value. Post was quick and the disc was well packaged in a foam lined box with larger outer box. This is excellent because there are many web complaints about other retailer's poor packaging. Comes with manufacturer's 2 year warranty which is not the case with some other sites. But beware that this disc is not a standard retail boxed item with cable, power adapter and software as might be inferred from the "What's in the box" blurb. It's a disc-only deal - see the "Additional" section towards the bottom of the first page.
  • Overall 5*
  • Ease of use 4*
  • Value for money 5*
7200 HDD, great for a games library
Reviewed by Joshua. Review Posted 09/09/2013
The only way I can fault the barracuda is noise levels, when you're booting something up on this drive the moving mechanical parts will create noise. Maybe more so than it's rivals, but the great thing is, it is an affordable 7200 RPM HDD that is reliable. If you can pay a premium for a Western Digital Black, then that should be considered too, but for the price these Barracudas are unbeatable.
  • Overall 4*
  • Ease of use 5*
Hmmmm
Reviewed by Peter. Review Posted 20/05/2013
OK, this is a decent enough drive. It runs decently fast - about as fast as a 7200 RPM 5.25" HD should run. I bought it to replace a 5-y.o. Western Digital Green HD which was beginning to give me some concern.
But - it hums. At 120Hz, so it's an insidious hum which isn't a multiple of UK mains hum, so it stands out from normal domestic background noise. I've attached Acoustifeet to my PC's case, and that seems to have mitigated the issue a little.
I should have known. I have a Maxtor external drive (with a Seagate drive inside) and it hums too. Western Digital again next time!
  • Overall 3*
  • Ease of use 2*
The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
Type: Hard drive
Capacity: 500GB
Brand: Seagate
Price Range Inc VAT: 0 - 50
