BT.com
Wishlist
Seagate 500GB Barracuda SATA-600 7200RPM 16MB 3.5" Hard Drive
Seagate 500GB Barracuda SATA-600...
£45.46
£45.46
Add to wishlist
Delivery
Standard Due date unavailable
The Seagate Desktop HDD is the one drive for every desktop system need, reliability and simplicity. Now available in capacities 500 MB. Count on Seagate to deliver the storage innovations that bring down your costs and crank up your storage.
Seagate Desktop HDDs with 500 MB-per-disk have advanced power modes to save more energy while in idle states - without sacrificing performance. Desktop HDDs are produced using the most sophisticated manufacturing process in the industry, with a focus on environmental stewardship.
Seagate Desktop HDD ST500DM002 - hard drive - 500 GB - SATA 6Gb/s
Hard drive - internal
500 GB
3.5" x 1/3H
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
16 MB
Native Command Queuing (NCQ), Perpendicular Magnetic Recording (PMR)
101.6 mm x 146.99 mm x 19.98 mm
415 g
Microsoft Certification
Compatible with Windows 7
2 years warranty
500 GB
3.5" x 1/3H
SATA 6Gb/s
Buffer Size
16 MB
Bytes per Sector
512
101.6 mm
146.99 mm
19.98 mm
415 g
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
144 MBps (read) / 125 MBps (write)
Reliability
Non-Recoverable Errors
1 per 10^14
Expansion & Connectivity
1 x SATA 6 Gb/s - 7 pin Serial ATA
Compatible Bay
3.5" x 1/3H
RoHS
60 °C
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
5* Excellent HDD
Reviewed by Gary Mason on 18/02/2012
I have been buying Seagate drives for 15+ years and have only ever had one fail but it was 3 1/2yrs old they are generally excellent drives this is my second Seagate 500GB Barracuda the previous drive I put into my Sky+HD box which also works a treat. Im only giving it 4 stars for value for money as I feel in general HDD's are still a bit over price. Performance wise you can't go to wrong.
5* Seagate 500GB - overall a good buy.
Reviewed by Anonymous on 05/12/2013
Have used Seagate/Maxtor for 2 decades without any problems so I stick with this make. This disk is one from the latest Seagate range and represents good cash/bytes value. Post was quick and the disc was well packaged in a foam lined box with larger outer box. This is excellent because there are many web complaints about other retailer's poor packaging. Comes with manufacturer's 2 year warranty which is not the case with some other sites. But beware that this disc is not a standard retail boxed item with cable, power adapter and software as might be inferred from the "What's in the box" blurb. It's a disc-only deal - see the "Additional" section towards the bottom of the first page.
4* 7200 HDD, great for a games library
Reviewed by Joshua on 09/09/2013
The only way I can fault the barracuda is noise levels, when you're booting something up on this drive the moving mechanical parts will create noise. Maybe more so than it's rivals, but the great thing is, it is an affordable 7200 RPM HDD that is reliable. If you can pay a premium for a Western Digital Black, then that should be considered too, but for the price these Barracudas are unbeatable.
3* Hmmmm
Reviewed by Peter on 20/05/2013
OK, this is a decent enough drive. It runs decently fast - about as fast as a 7200 RPM 5.25" HD should run. I bought it to replace a 5-y.o. Western Digital Green HD which was beginning to give me some concern.
But - it hums. At 120Hz, so it's an insidious hum which isn't a multiple of UK mains hum, so it stands out from normal domestic background noise. I've attached Acoustifeet to my PC's case, and that seems to have mitigated the issue a little.
I should have known. I have a Maxtor external drive (with a Seagate drive inside) and it hums too. Western Digital again next time!
Scroll to top
