BT.com
Wishlist
Seagate 4TB Surveillance HDD SATA 6Gb/s 5900RPM 64MB 3.5" Hard Drive
Delivery
Standard Due date unavailable
The Seagate Surveillance HDD addresses the need for high-resolution cameras and camera counts, and ensures cost-effective performance and durability in always-on surveillance systems.
Seagate Surveillance HDD ST4000VX000 - hard drive - 4 TB - SATA 6Gb/s
Hard drive - internal
4 TB
3.5" x 1/3H
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
64 MB
Spindle Speed
5900 rpm
RV Sensor, Native Command Queuing (NCQ), Seagate Think Green, Advanced Format technology
101.6 mm x 146.99 mm x 26.11 mm
610 g
3 years warranty
4 TB
3.5" x 1/3H
SATA 6Gb/s
Buffer Size
64 MB
101.6 mm
146.99 mm
26.11 mm
610 g
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
146 MBps
Seek Time
8.5 ms (average)
Spindle Speed
5900 rpm
Reliability
MTBF
1,000,000 hours
Non-Recoverable Errors
1 per 10^14
Load / Unload Cycles
300,000
Expansion & Connectivity
1 x SATA 6 Gb/s - 7 pin Serial ATA
Compatible Bay
3.5" x 1/3H
Power Consumption
8 Watt (active) , 0.75 Watt (standby) , 0.75 Watt (sleep)
Limited warranty - 3 years
70 °C
5 - 90% (non-condensing)
Shock Tolerance
80 g @ 2ms (operating) / 300 g @ 2ms (non-operating)
Scroll to top
