Click to visit BT.com
BT.com
Wishlist
Seagate 4TB NAS HDD SATA 6GB/s 64MB 3.5" Hard Drive
Leading performance for your NAS!
Quicklinx: 8QFHWS00
Mfr#: ST4000VN000
Form Factor: 3.5"
Type: Hard drive
Interface Type: Serial ATA-600
Capacity: 4TB
Spin Speed (rpm): 5900rpm
Express delivery Order within the next 5 hours for delivery tomorrow
20 in stock
£130.54
Essential accessories
Ideal for small business servers or home video and central storage, the Seagate® NAS HDDs are built and tested to provide industry-leading performance for small 1- to 5-bay NAS systems. Expect always-on, 24×7 reliability and the NASWorks™ technology features that simplify your installation, customise error recovery controls, and fine-tune power management and vibration tolerance.
Why choose the Seagate NAS HDD?
  • Performance. Built and tested to provide industry-leading performance for 24×7 NAS applications
  • Capacity: 4TB
  • NASWorks: Simplifies drive installation and improves reliability
  • Reliability: Always-on, 24×7--1M hours MTBF
  • 3 year warranty
  • Seagate NAS HDDs are built and tested to provide industry-leading performance for small NAS systems
  • NASWorks technology supports customized error recovery controls, power management and vibration tolerance for optimal performance and reliability in a 1- to 5-bay solution
  • NAS error recovery controls optimize drive health by helping to ensure drives are not dropped from the NAS and sent into a RAID rebuild
  • Improved vibration tolerance and emission in multi-drive systems with dual-plane balance
  • Advanced power management supports multiple power profiles for low-power, 24 x 7 performance
  • Industry-leading performance with NASWorks balances sequential and random performance, ideal for both small business and personal profiles
  • Quiet drive operation enhances customer experience in living room or office environments
  • 4 TB drives offer the highest capacity in purpose-built NAS storage
Best-Fit Applications
  • Home servers or desktop NAS solutions
  • Small-business file sharing
  • Backup servers
Evaluating HDDs for NAS Applications
When choosing the right drive for any application, there are many factors to take into consideration, including what the drive will be used for, what applications it will run, what requirements the environment will place on the drive, and what levels of capacity, performance, reliability or speed will be needed. With more data streaming into homes and small businesses than ever, there is greater demand for simple, centralised NAS storage arrays, but the demands on a drive in these systems are high.
Enter the Seagate® NAS HDD, the first Seagate drive purpose built for 1- to 5-bay NAS arrays. Traditionally, small NAS solutions employed desktop drives, but they demanded more than a typical desktop HDD could reliably deliver. Those demands include NAS error recovery controls, drive vibration and advanced power management features, all of which are addressed with Seagate NASWorks™ technology. By choosing Seagate NAS HDD with NASWorks, you can expect more reliable performance from your 1- to 5-bay NAS systems.
NAS Error Recovery Controls
Seagate NASWorks helps to ensure drives remain active in a RAID environment. For example, in a typical desktop environment, if a drive needs to rebuild data, it can take 20 seconds or longer. In a typical NAS application, if the drive takes longer than seven seconds to recover data, the RAID assumes the drive dropped out of the array and will start the time-consuming task of rebuilding the entire drive. With NASWorks, however, the drive will stop trying to recover data within seven seconds. Instead, the drive will notify the RAID that it needs help rebuilding a specific piece of data. The RAID can help correct that data from backups, and a full drive rebuild is avoided.
Dual-Plane Balance
Traditional desktop drives emit small levels of vibration because of their rotating magnetic platters. For laptop and desktop systems, the vibration of a single drive has little effect on a system. However, if the same desktop drive is integrated into a multi-drive environment such as a NAS box, the effects are amplified and can cause reductions in performance. For multi-drive applications, NASWorks helps dampen drive vibrations with dual-plane balance. By better balancing the drive motor, drive vibration is minimised, making it more reliable in 1- to 5-bay environments. (For larger environments, Seagate enterprise-class drives offer additional features to better displace the effects of vibration, further improving drive reliability.)
Finally, desktop drives are built to run in profiles that are somewhat parallel to your own working week. That is, they're expected to run on and off for multiple hours at a time, but not 24×7. NAS environments demand more and expect ready access to data. For that reason, NASWorks provides 24×7 operation profiles and advanced power management modes to help drives go into the appropriate sleep or standby mode; this maximises power conservation, minimises time-to-data and improves overall reliability and performance.
To avoid frustration and improve performance and reliability in multi-drive applications, choose drives that support these features. You will see performance improvement and better overall health in your NAS solution with Seagate NAS HDDs supported by NASWorks.
Seagate NAS HDD ST4000VN000 - hard drive - 4 TB - SATA 6Gb/s
Hard drive - internal
4 TB
SATA 6Gb/s
Buffer Size
64 MB
Halogen Free, NASWorks
101.6 mm x 146.99 mm x 26.11 mm
610 g
Microsoft Certification
Compatible with Windows 7
Business Storage STBM2000100, STBM2000200, STBM2000300, STBM3000100, STBM3000200, STBM3000300, STBM4000100, STBM4000200, STBM4000300, STBN100, STBN4000100, STBN4000200, STBN4000300, STBN6000100, STBN6000200, STBN6000300, STBN8000100, STBN8000200, STBN8000300, STBP100, STBP12000100, STBP12000200, STBP12000300, STBP16000100, STBP16000200, STBP16000300, STBP200, STBP4000100, STBP4000200, STBP4000300, STBP8000100, STBP8000200, STBP8000300
4 TB
SATA 6Gb/s
Buffer Size
64 MB
101.6 mm
146.99 mm
26.11 mm
610 g
Reliability
MTBF
1,000,000 hours
Non-Recoverable Errors
1 per 10^14
Start / Stop Cycles
600,000
Load / Unload Cycles
300,000
Expansion & Connectivity
1 x SATA 6 Gb/s
Compatible Bays
1 internal
70 °C
Seagate Business Storage STBM2000100, STBM2000200, STBM2000300, STBM3000100, STBM3000200, STBM3000300, STBM4000100, STBM4000200, STBM4000300, STBN100, STBN4000100, STBN4000200, STBN4000300, STBN6000100, STBN6000200, STBN6000300, STBN8000100, STBN8000200, STBN8000300, STBP100, STBP12000100, STBP12000200, STBP12000300, STBP16000100, STBP16000200, STBP16000300, STBP200, STBP4000100, STBP4000200, STBP4000300, STBP8000100, STBP8000200, STBP8000300
Seagate 4TB NAS HDD SATA 6GB/s 64MB 3.5 Bundle deal on Seagate 4TB NAS HDD SATA 6GB/s 64MB 3.5" Hard Drive
Including:
CoolerMaster High Performance Thermal Paste 2g CoolerMaster High Performance Thermal Paste 2g worth £4.83 | in stock
Akasa Cable Tidy Kit Akasa Cable Tidy Kit worth £4.62 | in stock
StarTech.com 7 Piece Precision Screwdriver Computer Tool Kit StarTech.com 7 Piece Precision Screwdriver Computer Tool Kit worth £11.61 | in stock
Best Value Duratool Antistatic Wrist Band Best Value Duratool Antistatic Wrist Band worth £3.60 | while stocks last
C2G 1m 7-pin 180° to 90° 1-Device Serial ATA Cable C2G 1m 7-pin 180° to 90° 1-Device Serial ATA Cable worth £3.58 | in stock
£150.07
saving £8.68
Cables (1)
Cables
Including:
£132.32
saving £1.78
Options (2)
Including:
£132.34
saving £1.80
Including:
Corsair Flash Voyager Slider - 32GB - USB 3.0 Corsair Flash Voyager Slider - 32GB - USB 3.0 worth £9.88 | in stock
£140.53
Resources
The following resources are available for the Seagate 4TB NAS HDD SATA 6GB/s 64MB 3.5" Hard Drive
Form Factor: 3.5"
Type: Hard drive
Capacity: 4TB
Brand: Seagate
Price Range Inc VAT: 100 - 150
