BT.com
Wishlist
Seagate 4TB Backup Plus USB 3.0 3.5" Desktop Hard Drive
Delivery
Standard Due date unavailable
Seagate Backup Plus, easy backup for your digital life on your computer and the cloud
The Seagate® Backup Plus desktop drive simplifies backup for consumers who want to protect their entire digital life locally, in the cloud or from social networks. Via the Seagate Dashboard, use the Protect function to set up a one-click plan or customize your scheduled local backup. Keep multiple copies of your files in case disaster strikes.
With the Save feature, user-generated content can be backed up from your favorite social networks. Many people now use their smartphones to capture priceless moments. While these devices are handy and readily available, storage is not their strong suit. Capture a memory, post it on a social networking site and let the Seagate Dashboard automatically back up any content posted. Even if the file gets accidentally deleted from the device, another copy can be waiting.
The Share feature allows multiple files to be uploaded to social networks at once from your computer. The days of uploading individual files without creating a new album are gone! Simply select files to upload, choose where to post them and even add comments. Managing your social profile has never been easier.
Install the pre-loaded NTFS driver for Mac, and use the drive interchangeably between PC and Mac® computers without reformatting the drive. For even more flexibility, with the Seagate Backup Plus design, you can upgrade from the included USB 3.0 interface to Thunderbolt™ technology or FireWire® 800 with the available additional adapter.
  • Windows® 7, Windows Vista®, Windows XP SP3 (32-bit and 64-bit) operating system or Mac OS X 10.6 or higher1
  • SuperSpeed USB 3.0 port (required for USB 3.0 transfer speeds or backwards compatible with USB 2.0 ports at USB 2.0 transfer speeds)2
Inside the Box
  • Seagate Backup Plus drive
  • 4-foot USB 3.0 cable
  • Seagate Dashboard pre-loaded on drive
  • Power adapter
  • NTFS driver for Mac pre-loaded on drive1
  • Quick start guide
  • USB 3.0 interface adapter with capacity gauge
  • 2-year limited warranty
Seagate Backup Plus STCA4000200 - hard drive - 4 TB - USB 3.0
Hard drive - external (desktop)
4 TB
USB 3.0
Data Transfer Rate
5.0 Gbps (USB 3.0)
Built-in capacity meter, automatic backup
Power Source
Included AC adapter
12.4 cm x 4.4 cm x 15.8 cm
1.08 kg
Middle East, Africa, Europe
2 years warranty
4 TB
USB 3.0
12.4 cm
4.4 cm
15.8 cm
1.08 kg
Performance
Interface Transfer Rate
5.0 Gbps (USB 3.0)
Expansion & Connectivity
1 x USB 3.0
Power Source
Included AC adapter
Power adapter
Apple MacOS X 10.6 or later, Microsoft Windows XP SP3, Microsoft Windows Vista / 7
USB adapter
1 x USB 3.0 cable - 1.2 m
Resources
The following resources are available for the Seagate 4TB Backup Plus USB 3.0 3.5" Desktop Hard Drive
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
5* I met Dunc!
Reviewed by Mike Sutcliffe on 11/04/2013
The famous Dunc from BT recommended this to me. I saw him at the Gadget Show, looks just like his picture with big bushy eyebrows. Big button babe was also there. She was the 3rd fittest bird I saw that weekend! And... back to the product. I've just bought this delicious piece of hardware for backing up my files. If you could travel faster than the speed of light this would be the vehicle you'd sit down on.
Scroll to top
