Seagate 3TB Expansion USB 3.0 3.5" Desktop Drive
Standard Due date unavailable
Seagate Expansion desktop drive, add-on storage for your PC
The Seagate® Expansion desktop drive provides extra storage for your ever-growing collection of files. Instantly add space for more files, consolidate all of your files to a single location, or free up space on your computer's internal drive to help improve performance. Setup is straightforward; simply plug in the included power supply and USB cable, and you are ready to go. It is automatically recognized by the Windows® operating system, so there is no software to install and nothing to configure. Saving files is easy too--just drag-and-drop.
Take advantage of the fast data transfer speeds with the USB 3.0 interface by connecting to a SuperSpeed USB 3.0 port. USB 3.0 is backwards compatible with USB 2.0 for additional system compatibility.
  • Windows® 7, Windows Vista®, Windows XP SP3 (32-bit and 64-bit) operating system
  • SuperSpeed USB 3.0 port (required for USB 3.0 transfer speeds or backwards compatible with USB 2.0 ports at USB 2.0 transfer speeds)1
Inside the Box
  • Seagate Expansion drive
  • 18-inch USB 3.0 cable
  • 2-year limited warranty (EMEA)
  • Quick start guide
Seagate Expansion Desktop STBV3000200 - hard drive - 3 TB - USB 3.0
Hard drive - external ( desktop )
3 TB
USB 3.0
Power Source
Included AC adapter
Enclosure Colour
118 mm x 179.5 mm x 37.5 mm
940 g
2 years warranty
3 TB
USB 3.0
118 mm
179.5 mm
37.5 mm
940 g
Expansion & Connectivity
1 x USB 3.0
Power Source
Included AC adapter
Microsoft Windows XP (32/64 bits) SP3, Microsoft Windows Vista / 7 / 8
1 x USB 3.0 cable - 1.2 m
Enclosure Colour
The following resources are available for the Seagate 3TB Expansion USB 3.0 3.5" Desktop Drive
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
5* Works fine with Linux
Reviewed by Neil on 13/11/2013
I purchased the drive to back-up my Linux server. Despite the specification saying only Windows and MAC support, I found on the Seagate website that although not officially supported by Seagate for Linux use, they say their drives should work and indeed I am pleased to say this one works fine.
4* Gamerj27
Reviewed by Anonymous on 15/08/2012
This is an excellent choice for a fast expansion drive. Easy to use with plug and play feature. This happened to be the first USB 3.0 device I have used and I'm very impressed. Took 2mins to copy a 30GB file.
However, due to 4K sector layout it is not compatible as a backup drive using windows 7 backup utility.
Pros: Fast and affordable
Cons: Not a good Backup drive
2* Otherwise good product spoilt by cable
Reviewed by Anonymous on 26/04/2014
I bought this product some time ago and was slightly annoyed that I could not replace the cable due to a non-standard USB cable (the socket on the drive is not standards compliant).
This meant a longer cable could not be purchased later making awkward to use with a laptop unless at a desk.
The cable also proved to be highly temperamental causing the drive to become unavailable at unpredictable times. Within less than one year of purchase this made the drive virtually unusable and seagate refused to supply a new cable suggesting that I replace the drive.
When the cable does work the drive is quick and storage is reliable but accessing the drive is so patchy that it is made of little use.
Scroll to top
