Click to visit BT.com
BT.com
Wishlist
Seagate 3TB Barracuda SATA 6GB/s 64MB 7200RPM 3.5" Hard Drive
4.0*
Quicklinx: 7W95WS00
Mfr#: ST3000DM001
Form Factor: 3.5" x 1/3H
Type: Hard drive
Interface Type: Serial ATA-600
Capacity: 3TB
Spin Speed (rpm): 7200rpm
Express delivery Order within the next 19 hours for delivery on Wednesday
16 in stock
£87.63
Essential accessories
The Seagate Desktop HDD is the one hard drive for all your desktop applications. One drive for every need, supported by trusted performance, reliability and simplicity.
Seagate Desktop HDD ST3000DM001 - hard drive - 3 TB - SATA 6Gb/s
Hard drive - internal
3 TB
3.5" x 1/3H
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
64 MB
Spindle Speed
7200 rpm
Native Command Queuing (NCQ), Perpendicular Magnetic Recording (PMR), Seagate OptiCache technology, Seagate AcuTrac technology
101.6 mm x 146.99 mm x 26.11 mm
626 g
Microsoft Certification
Compatible with Windows 7
2 years warranty
3 TB
3.5" x 1/3H
SATA 6Gb/s
Buffer Size
64 MB
Bytes per Sector
512
101.6 mm
146.99 mm
26.11 mm
626 g
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
210 MBps (read) / 156 MBps (write)
Spindle Speed
7200 rpm
Reliability
Start / Stop Cycles
300,000
Expansion & Connectivity
1 x SATA 6 Gb/s - 7 pin Serial ATA
Compatible Bays
1 x 3.5" x 1/3H - internal
RoHS
60 °C
Seagate 3TB Barracuda SATA 6GB/s 64MB 7200RPM 3.5 Bundle deal on Seagate 3TB Barracuda SATA 6GB/s 64MB 7200RPM 3.5" Hard Drive
Including:
CoolerMaster High Performance Thermal Paste 2g CoolerMaster High Performance Thermal Paste 2g worth £4.83 | in stock
Akasa Cable Tidy Kit Akasa Cable Tidy Kit worth £4.20 | in stock
StarTech.com 7 Piece Precision Screwdriver Computer Tool Kit StarTech.com 7 Piece Precision Screwdriver Computer Tool Kit worth £11.61 | in stock
Best Value Duratool Antistatic Wrist Band Best Value Duratool Antistatic Wrist Band worth £3.60 | while stocks last
C2G 1m 7-pin 180° to 90° 1-Device Serial ATA Cable C2G 1m 7-pin 180° to 90° 1-Device Serial ATA Cable worth £3.58 | in stock
£107.16
saving £8.26
Cables (1)
Cables
Including:
£89.41
saving £1.78
Other bundles (2)
Including:
£89.43
saving £1.80
Including:
Intenso 32GB Rainbow Transparent USB Flash Drive Intenso 32GB Rainbow Transparent USB Flash Drive worth £5.48 | in stock
£91.72
saving £1.39
7W95 StarTech.com 3.5in Black USB 3.0 External SATA III Hard Drive Enclosure with UASP for SATA 6 Gbps In Stock £33.72
7W95 StarTech.com USB 3.0/eSATA Dual 3.5" SATA III Hard Drive External RAID Enclosure w/ UASP - Black In Stock £79.81
7W95 StarTech.com 3 Bay Aluminum Trayless Hot Swap Mobile Rack Backplane for 3.5in SAS II/SATA III In Stock £76.44
Customer reviews
Write a review for the Seagate 3TB Barracuda SATA 6GB/s 64MB 7200RPM 3.5" Hard Drive here!
Very good
Reviewed by Bill. Review Posted 09/01/2014
I bought this hard drive from BT after receiving a DOA drive from Amazon, I was so happy with my past purchases from BT i believed that this order should be perfectly fine. It arrived very quick and worked out of the box! Surprisingly it is even cheaper than buying from Amazon!!! Recommend to all my friends
  • Overall 5*
  • Ease of use 5*
  • Value for money 5*
Read first about 3Tb
Reviewed by George . Review Posted 28/10/2012
I know that I will sound very silly to everybody who knows about computers, but this comment is for those who know very little. 3Tb drives need a different protocol for formatting. If you follow the defaults when you install the 3Tb, you end up with 2Tb drive and some large unassigned space. Perhaps you can re-format, but in my case this was too late. Here is the story: "The drive has to be reformatted as a GPT-formatted drive instead of an MBR-formatted drive. The old standard MBR partition tables can't describe a drive of over about 2.13 TiB. You can convert only empty, unpartitioned disks (raw drives or empty MBR drives) to the GPT format."
  • Overall 5*
  • Ease of use 3*
Fast and quiet
Reviewed by BryanP. Review Posted 09/10/2013
Excellent drive. Had to configure as GPT to ensure that all 3TB accessible, but easy to do in Windows 7. Have hit it hard over recent weeks loading tons of videos onto it. So far faultless. It does spin down if not in use, but not really a problem.
  • Overall 5*
  • Ease of use 5*
  • Value for money 4*
Better twit then chirp! ;(
Reviewed by Rafal. Review Posted 10/02/2013
For those that are not aware of ongoing, long-time dragging "chirping" issue of Shee..gate disc. I'm one of those victims myself and only realised once I got them. LOL 2 devices. Both singing well. But that wasn't the purpose of having 2x3TB storage :(. FYI: The chirping sound is caused by disc heads being parked on random. I guess I could stand the sound at the end of the day but major let down is at some stage you will have the disc parked in a middle of r/w transaction and the only way to bring it up is to power cycle the disc. Unfortunately SG's efforts to eliminate this problem have been failure so far including most recent firmware CC4H. Obviously any requests towards SG online end up advising firmware upgrade. Don't be fooled. So If you're not big fan of a soprano coming out from within your machine you better have a piece of Caviar. Ta, ta. R.
  • Overall 3*
  • Ease of use 4*
  • Value for money 3*
bit hard to install win 7 and slow
Reviewed by jason. Review Posted 21/04/2014
for a new pc build using a amd 8350fx asrock 990fx extreme 3 board .getting the full 3tera was a nightmare but after finding few things off the net i got the had drive installed in gpt format .i found the hard drive very slow .so i tryed my 250gb sata drive and its very fast .cant understand why the drive slowed my win 7 pro 64bit right down .next time on i use a 2 tera to be safer
  • Overall 3*
  • Ease of use 2*
Repeat failures
Reviewed by Anonymous Review Posted 10/10/2015
I have had 2 of these fail - one inside the 2 year warranty and the other after 26 months. Have replaced with same drives on both occassions as I use in a NAS Server with a RAID back up.
  • Overall 2*
  • Ease of use 5*
Two failed, avoid these
Reviewed by Jon. Review Posted 27/12/2015
I bought two of these a couple of years back to use in a mirrored configuration. Both failed, one within a year and the second within two years, just now at time of review. Fortunately I was able to replace the first immediately to restore the mirror and also kept other backups... I don't recommend these.
  • Overall 1*
  • Ease of use 1*
  • Value for money 1*
The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
Type: Hard drive
Capacity: 3TB
Brand: Seagate
Price Range Inc VAT: 50 - 100
