BT.com
Wishlist
Seagate 320GB Laptop Thin HDD SATA 6GB/s 7200RPM 2.5" 7mm Hard Drive
Seagate 320GB Laptop Thin HDD SATA...
£46.44
7 in stock
£46.44
Add to wishlist
Delivery
Standard 3-5 working days
Seagate Laptop Thin HDD offers feature-rich, slim, lightweight style at price and capacity points that enable no-compromise designs for thin computing.
Seagate has purpose-built the Laptop Thin HDD to meet customers' demand for affordable, slimmer, fully functional computing solutions.
Seagate Laptop Thin HDD drives leverage current laptop drives in both material and product design to provide the world's first 7 mm 2.5-inch form factor drive. The result is affordable, thin storage for entry-level to mainstream laptops, high-end netbooks, thin ultra portables and slim-computing devices.
Seagate Laptop Thin HDD ST320LM010 - hard drive - 320 GB - SATA 6Gb/s
Hard drive - internal
320 GB
2.5"
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
32 MB
Spindle Speed
7200 rpm
QuietStep, Ramp Load
70.1 mm x 100.55 mm x 7 mm
95 g
Microsoft Certification
Compatible with Windows 7
320 GB
2.5"
SATA 6Gb/s
Buffer Size
32 MB
Bytes per Sector
4096
70.1 mm
100.55 mm
7 mm
95 g
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
135 MBps
Seek Time
11 ms (average)
Spindle Speed
7200 rpm
Reliability
Non-Recoverable Errors
1 per 10^14
Load / Unload Cycles
600,000
Expansion & Connectivity
1 x SATA 6 Gb/s - 7 pin Serial ATA
Compatible Bay
2.5"
Power Consumption
1.8 Watt (active) , 0.65 Watt (idle)
60 °C
Shock Tolerance
400 g @ 2ms (operating) / 1000 g @ 1ms (non-operating)
Seagate 320GB Laptop Thin HDD SATA 6GB/s 7200RPM 2.5"...
£46.44
Save on this ideal PC Build kit!
Save £10.36
£65.99
Cables - Cables
£46.44
Save 50% On This 1m SATA Cable When Bought With This Item
Save £3.60
£50.04
Scroll to top
