Click to visit BT.com
BT.com
Wishlist
Seagate 2TB Expansion USB 3.0 3.5" Desktop Drive
5.0*
Quicklinx: 84C7WS00
Mfr#: STBV2000200
Seagate Expansion desktop drive, add-on storage for your PC
The Seagate® Expansion desktop drive provides extra storage for your ever-growing collection of files. Instantly add space for more files, consolidate all of your files to a single location, or free up space on your computer's internal drive to help improve performance. Setup is straightforward; simply plug in the included power supply and USB cable, and you are ready to go. It is automatically recognized by the Windows® operating system, so there is no software to install and nothing to configure. Saving files is easy too--just drag-and-drop.
Take advantage of the fast data transfer speeds with the USB 3.0 interface by connecting to a SuperSpeed USB 3.0 port. USB 3.0 is backwards compatible with USB 2.0 for additional system compatibility.
  • Windows® 7, Windows Vista®, Windows XP SP3 (32-bit and 64-bit) operating system
  • SuperSpeed USB 3.0 port (required for USB 3.0 transfer speeds or backwards compatible with USB 2.0 ports at USB 2.0 transfer speeds)1
Inside the Box
  • Seagate Expansion drive
  • 4 foot USB 3.0 cable
  • 2-year limited warranty (EMEA)
  • Quick start guide
Seagate Expansion Desktop STBV2000200 - hard drive - 2 TB - USB 3.0
Hard drive - external ( desktop )
2 TB
USB 3.0
Power Source
Included AC adapter
Enclosure Colour
118 mm x 179.5 mm x 37.5 mm
940 g
EMEA
2 years warranty
2 TB
USB 3.0
118 mm
179.5 mm
37.5 mm
940 g
Expansion & Connectivity
1 x USB 3.0
Power Source
Included AC adapter
Microsoft Windows XP (32/64 bits) SP3, Microsoft Windows Vista / 7 / 8
1 x USB 3.0 cable - 1.2 m
Enclosure Colour
EMEA
Resources
The following resources are available for the Seagate 2TB Expansion USB 3.0 3.5" Desktop Drive
Customer reviews
Write a review for the Seagate 2TB Expansion USB 3.0 3.5" Desktop Drive here!
Great Desktop Drive
Reviewed by Matt. Review Posted 03/06/2013
Very speedy drive over usb3.
I have taken the drive out of the case to see which drive is inside and it was an st2000dm001 though that doesn't mean a lot. The important bit is the serial number mine was Z1Exxxxx. The Z means that it was made in Thailand and the E means that it is one of the 2 platter hdd's. I found this guide.
S - SU - Suzhou China
W - WU - Wuxi China
Z - TK - Korat Thailand
F = 3 platters with either 5 or 6 heads, while E = 2 platters.
This means that it is one of the better models.
I have seen this drive cheaper from other places but I used a 10% off token.
Highly recommended drive.
Matt
  • Overall 5*
  • Ease of use 5*
  • Value for money 5*
Superb, simple and efficient
Reviewed by Anonymous Review Posted 25/05/2014
I bought this expansion hard drive to quickly transfer all my files from my computer in preparation for an operating system update. The hard drive plugged into the USB port and worked straight away without any installation or thought.
The drive performed brilliantly and without errors. Transfer speed is very good even on USB 2.0 and there is really nothing much to worry about.
The only improvements I'd like to see would be that the drive powers down after a period of inactivity and better vibration damping properties. On a hard desk there is a low frequency hum, but this can easily be fixed by putting 4 foam pads under each hard foot. The underside of the device must have an air gap as the device can get quite warm if actively used for long periods.
Pure simplicity and great value for money.
  • Overall 5*
  • Ease of use 5*
Works on Linux Fine
Reviewed by Anonymous Review Posted 09/06/2014
I've had no problems using this drive as a user home directory on Linux (allowing me to free up space on my main drive for apps/OS). Formatting to ext4 takes forever though, so I decided to do a lazy init table format (-E lazy_itable_init) instead. Works fine. Happy with the purchase.
  • Overall 5*
  • Ease of use 5*
great
Reviewed by Anonymous Review Posted 16/07/2014
It was so simple to use and has loads of space to putall your work and more.
  • Overall 5*
  • Ease of use 5*
Reviewed by Anonymous Review Posted 08/02/2013
Bought 6 when they were on offer. 2 were dodgy; refused to mount. Sent back to BT.com for refund which I got without issue. Other 4 were no problem. Fast drive, fast transfer by USB3. It's just a black box; there's only one power/transfer LED (blue) and that's your lot.
  • Overall 4*
  • Ease of use 5*
Warning! Will not work with Windows Backup
Reviewed by Chris. Review Posted 11/04/2014
I purchased two of these to use to back up my data. One being used, one offsite.
I use Windows 7 Backup scheduled to backup at midnight each day. Or at least I would have liked to!
These drives are not supported by Windows Backup since they use a 4K sector size. A technological advancement that has been around for years and Microsoft are intent on ignoring for anything other than Win8.
Note: This is not Seagates fault but MS's, however it would be nice if Seagate (who do know about this issue) state this fact and stop people wasting their money.
These drives do however work, quite adequately as external hard drives if all you want to do is copy files over manually.
Shame really.
  • Overall 1*
  • Ease of use 1*
  • Value for money 1*
The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
