BT.com
Wishlist
Seagate 2TB Desktop SSHD 7200RPM SATA 6GB/s 64MB 3.5" 8GB SSD Cache
Seagate 2TB Desktop SSHD 7200RPM...
£93.55
SSD Performance. HDD Capacity. Affordable Price.
Hurry, only 1 left in stock!
£93.55
Add to wishlist
Delivery
Standard 1-3 working days
Express Delivered on Friday
Express Delivery
  • 00 h
  • 00 m
  • 00 s
Buy a Seagate Desktop SSHD today and receive a Dying Light Season Pass. Once you have bought your product, email duncsdeals@dabs.com with your Name, Email Address and Sales Order Number and you will receive a follow up email within 48 hours with your code.
Performance. Capacity. Affordable Price.
The wait is over for a solid state hybrid drive in a 3.5-inch form factor. The Seagate® Desktop SSHD delivers SSD-like performance and massive capacities at an affordable price. Don't waste time and money on a dual drive solution to get the high performance and capacity you demand for:
  • Desktop PCs
  • Workstations
  • Direct-attached storage (DAS) devices
The Seagate® Desktop SSHD is here with breakthrough technology that identifies and stores to flash only your most frequently used data. You can boot up and launch applications faster while still having the massive capacities you need for everything else. Choose performance and capacity with 8GB of MLC NAND flash and up to 2TB of HDD capacity. 3-year limited warranty.
Why choose the Desktop SSHD?
  • Simple. An all-in-one storage solution
  • Performance. SSD-like performance to give you the boost you crave
  • Capacity. The capacity you need--up to 2TB
  • Price. An affordable price that makes sense
  • The first solid state hybrid drive (SSHD) in a 3.5-inch form factor
  • Boots up and performs like an SSD1
  • SATA 6Gb/s with NCQ for interface speed
  • Faster than a traditional HDD1
  • All-in-one design for simplicity and ease of installation
  • Installs and operates like a standard hard drive: cross-platform, no drivers or additional software required
  • Massive 1TB or 2TB capacities combined with SSD-like performance1
  • Backed by a 3-year limited warranty
Solid State Drive Technology Inside Your SSHD
SSHD technology uses the right amount of ultra-fast NAND flash (the same type used in SSDs) to increase system performance. Seagate's Adaptive Memory ™ technology effectively identifies the most frequently-used data and stores it in the NAND flash. The results give you greatly improved boot times, application loads and overall system responsiveness.
Get it all - desktop speed and capacity.
With SSHD technology, there is no need to trade capacity for high performance. The Seagate® Desktop SSHD is available in 1TB and 2TB capacities, giving you plenty of space for all of your digital content. Store up to 1,000 video games, 2,000 hours of video, 500 HD DVDs, 640,000 digital photos, or over 33,000 hours of mp3 music files.* *Quantitative usage examples for various applications are for illustrative purposes. Actual quantities will vary based on several factors, including file size, file format, features and application software.
Affordable and reliable SSHD for your desktop
SSHDs fuse the strength of SSD and HDD into one affordable and powerful device. You'll be surprised at how little you have to pay to get SSD-like performance in your desktop system.
And since SSD fuses the strengths of both HDD and SSD technologies, you get the combined reliability of both in a solid state hybrid drive product.
Easy, Low-cost HDD Desktop Upgrade
SSHD provides a great way to breath new life into an older desktop computer.
  • Get performance you never thought possible from your old system
  • One of the most cost-effective ways to increase the performance of your system.
Spec
  • Capacity: 2TB
  • NAND Type/Size: MLC/8GB
  • Interface: SATA 6Gb/s NCQ
  • Cache 64MB
  • Average Data Rate, Read, Avg All Zones up to 156MB/s
  • Average Data Rate From NAND Media up to 190MB/s
  • Operating Temperature: 0°C to 60°C
Seagate Desktop SSHD - hybrid hard drive - 2 TB - SATA 6Gb/s
Hybrid hard drive - internal
2 TB
Flash Memory Capacity
8 GB
NAND Flash Memory Type
Multi-level cell (MLC)
3.5" x 1/3H
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
64 MB
Native Command Queuing (NCQ), SSHD
101.6 mm x 146.99 mm x 26.11 mm
626 g
Microsoft Certification
Compatible with Windows 7
3 years warranty
2 TB
8 GB
3.5" x 1/3H
SATA 6Gb/s
Buffer Size
64 MB
Bytes per Sector
4096
101.6 mm
146.99 mm
26.11 mm
626 g
Performance
Drive Transfer Rate
600 MBps (external)
Seek Time
9.5 ms (average)
Reliability
Non-Recoverable Errors
1 per 10^14
Start / Stop Cycles
300,000
Expansion & Connectivity
1 x SATA 6 Gb/s - 7 pin Serial ATA
Compatible Bay
3.5" x 1/3H
Power Consumption
6.7 Watt (active) , 0.9 Watt (idle)
Limited warranty - 3 years
60 °C
Seagate 2TB Desktop SSHD 7200RPM SATA 6GB/s 64MB 3.5"...
£93.55
Save on this ideal PC Build kit!
Save £9.25
£113.11
Cables - Cables
£93.55
Save 50% On This 1m SATA Cable When Bought With This Item
Save £3.61
£97.16
Resources
The following resources are available for the Seagate 2TB Desktop SSHD 7200RPM SATA 6GB/s 64MB 3.5" 8GB SSD Cache
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
5* I have my computer back; and it's even FASTER!
Reviewed by Tim Mak on 19/06/2014
I was about to write off my iMac as 'space junk' when the new OS Mavericks came along and bloated up my system with un-necessary tasks. The computer became so slow, I just wanted to chuck it out. Then the helpful young lad at the Genius Bar made the super suggestion to max out my RAM and get an SSD/SSHD instead of shelling out for a whole new computer. Did just as he suggested and WOW! It's like getting a whole new computer. Startup times are now ridiculously fast. I'm not a heavy user who just surfs, watches movies and listens to music. For that kind of use, this computer feels fast again. Almost as fast as when I had Snow Leopard on my system. Get this, max out your RAM, and you can cheat Apple out of another sale for a few more years, all for under £100. Well done Seagate.
5* Try it.
Reviewed by Mark on 01/03/2015
Windows 7 Ultimate with all of my applications installed (30+), boots in 8 seconds. Beyond my expectations, since I have watched ssd vs sshd tests showing slower times.
Got this running on an Asus A88XM-A.
Installed Windows 7 on a 64Gb primary partition, the rest of the space divided and wrapped up in extended.
Windows experience score is in ERROR for this hard drive.
5* Very pleased
Reviewed by Tim Mak on 20/07/2014
Installed in my iMac 2008. Feels like a new computer. The OS now loads up very quickly. This drive is good for users who just do a bit of surfing and watch movies.
5* System revived
Reviewed by John on 09/03/2015
I fitted this drive in the hope that it would make an ageing Windows 7, 64 bit system, a useable machine again. I could not be more pleased. I use the machine for browsing, general office tasks and a little music and video editing. This disc has improved boot times extraordinarily and the more I use the system, the faster it seems to become.
1* Sector errors within a few months and now failing
Reviewed by Anonymous on 12/08/2015
I bought this 2TB hybrid SSD in December 2014. I noticed average performance in my Microserver in which Windows Home Server was installed on the Seagate disk so installed Hard Disk Sentinel, which told me the drive was at 88% health. After just a few months. Not good.
It's since been worse and health of the drive is slowly dropping. I've run the Seagate diagnostics - well, tried to, it could only complete the quick test which told me the drive was knackered and needs replacing, the long test just caused the tools to crash.
I've now had to reinstall the OS on another disk (Clonezilla couldn't clone it because of the corrupted sectors), which is a ballache in itself, but I also have to wait for Seagate to receive it, check it and then send out a replacement. They do not have a facility for me to register my credit card and be sent a replacement first so they can charge me if I don't return the faulty one.
I won't touch Seagate again, sticking with Western Dig
Scroll to top
