Click to visit BT.com
BT.com
Wishlist
Seagate 2TB Backup Plus USB 3.0 3.5" Desktop Drive
Quicklinx: 84CBWS00
Mfr#: STCA2000200
Seagate Backup Plus, easy backup for your digital life on your computer and the cloud
The Seagate® Backup Plus desktop drive simplifies backup for consumers who want to protect their entire digital life locally, in the cloud or from social networks. Via the Seagate Dashboard, use the Protect function to set up a one-click plan or customize your scheduled local backup. Keep multiple copies of your files in case disaster strikes.
With the Save feature, user-generated content can be backed up from your favorite social networks. Many people now use their smartphones to capture priceless moments. While these devices are handy and readily available, storage is not their strong suit. Capture a memory, post it on a social networking site and let the Seagate Dashboard automatically back up any content posted. Even if the file gets accidentally deleted from the device, another copy can be waiting.
The Share feature allows multiple files to be uploaded to social networks at once from your computer. The days of uploading individual files without creating a new album are gone! Simply select files to upload, choose where to post them and even add comments. Managing your social profile has never been easier.
Install the pre-loaded NTFS driver for Mac, and use the drive interchangeably between PC and Mac® computers without reformatting the drive. For even more flexibility, with the Seagate Backup Plus design, you can upgrade from the included USB 3.0 interface to Thunderbolt™ technology or FireWire® 800 with the available additional adapter.
  • Windows® 7, Windows Vista®, Windows XP SP3 (32-bit and 64-bit) operating system or Mac OS X 10.6 or higher1
  • SuperSpeed USB 3.0 port (required for USB 3.0 transfer speeds or backwards compatible with USB 2.0 ports at USB 2.0 transfer speeds)2
Inside the Box
  • Seagate Backup Plus drive
  • 4-foot USB 3.0 cable
  • Seagate Dashboard pre-loaded on drive
  • Power adapter
  • NTFS driver for Mac pre-loaded on drive1
  • Quick start guide
  • USB 3.0 interface adapter with capacity gauge
  • 2-year limited warranty
Seagate Backup Plus STCA2000200 - hard drive - 2 TB - USB 3.0
Hard drive - external ( desktop )
2 TB
USB 3.0
Automatic backup
12.4 cm x 4.4 cm x 15.8 cm
1.08 kg
EMEA
2 years warranty
2 TB
USB 3.0
Automatic backup
12.4 cm
4.4 cm
15.8 cm
1.08 kg
Expansion & Connectivity
1 x USB 3.0
Power adapter
Microsoft Windows Vista / XP / 7, Apple MacOS X 10.6 or later
1 x USB cable - 1.2 m , 1 x USB adapter
EMEA
2 years warranty
Service & Support Details
Resources
The following resources are available for the Seagate 2TB Backup Plus USB 3.0 3.5" Desktop Drive
