Click to visit BT.com
BT.com
Wishlist
Seagate 1TB Laptop SSHD SATA 6GB/s 64MB 9.5mm Hard Drive - Compatible with PS4
Momentus XT SSHD Fuse SSD Speeds & High Capacity!
5.0*
Quicklinx: 8KRVWS00
Mfr#: ST1000LM014
Form Factor: 2.5" x 1/8H
Type: Hybrid hard drive
Interface Type: Serial ATA-600
Capacity: 1TB
Spin Speed (rpm): 5400rpm
Express delivery Order within the next 3 hours for delivery tomorrow
£74.98
Essential accessories
9.5mm Design Ideal For PS4 Upgrade
Seagate® Laptop and Laptop Thin SSHDs fuse the lightning speed of SSD with the high capacity of a hard drive. Powered by Seagate Adaptive Memory™ technology, SSHD improves boot times and application speed dramatically, unleashing your system's performance.
  • 1TB, 9.5mm design for maximum capacity laptops
  • Boots up and performs like an SSD
  • Up to 5 times faster than a traditional 5400-RPM HDD
  • Easy laptop upgrade to boost performance and capacity.
SSHDs use Seagate flash management technology to deliver SSD-like performance. Testing consistently shows that Seagate Laptop SSHDs compare favourably to SSDs--without sacrificing capacity.
SSD + HDD - The best of both worlds.
Seagate Laptop SSHDs integrate NAND flash solid-state storage with traditional hard drive storage, creating a laptop drive with the speed of solid state and the capacity of a hard drive.
  • No need to compromise performance over capacity
  • Installs and works like a typical hard drive
  • Unmatched data integrity and reliability by maximising the strengths of both flash and hard drive storage
  • Performance optimised by Seagate Adaptive Memory™ technology
SSHD is affordable.
SSHDs fuse the strength of SSD and HDD into one affordable and powerful device. You do not have to compromise capacity over performance anymore. With an SSHD, you can have it all. It is the latest and most affordable way to maximise every penny you invest in your PC.
Easy, low-cost HDD laptop upgrade: SSHD provides a great way to breath new life into an older laptop computer.
  • Get performance you never thought possible from your old system
  • One of the most cost-effective ways to increase performance in your PC or MAC system.
  • Easy DIY laptop upgrade solutions available
Seagate Adaptive Memory™ technology effectively identifies the most frequently-used data in your computer. This data is stored in the ultra-fast NAND flash memory, which results in blazing fast boot times and a super-responsive experience where you wait less and do more. This technology is constantly working and adapting to the way you work and access information.
PC & Mac Compatible.
Your Seagate® Laptop SSHD or Laptop Thin SSHD is designed to work in any standard laptop system. Unlike other "hyrbrid" solutions, there are no special drivers or software to install and configure. It installs and works just like a hard drive - only faster!
Affordable and reliable SSHD for your laptop.
SSHDs fuse the strength of SSD and HDD into one affordable and powerful device. You'll be surprised at how little you have to pay to get SSD-like performance in your laptop.
And since SSD fuses the strengths of both HDD and SSD technologies, you get the combined reliability of both in a solid state hybrid drive product.
Specification
  • Capacity: 1 TB
  • Interface: SATA 6Gb/s NCQ
  • NAND Type/Size: MLC/8GB
  • DRAM Cache (MB): 64
  • SATA Transfer Rates Supported (Gb/s): 6.0/3.0/1.5
  • Average Data Throughput (MB/s): 100
  • PC Mark Vantage Average HDD Score: 19,838
  • Average Windows 8 Boot Time (sec): <10
  • Seek Average, Read (ms): <12.0
  • Seek Average, Write (ms): <14
  • Heads/Disks: 4/2
  • Bytes per Sector: 4096
  • Head-Rest Method: QuietStepâ„¢ Ramp Load
  • Load/Unload Cycles: 600,000
  • Norecoverable Read Errors per Bits Read, Max: 1 per 10E14
  • Predicted Annualized Failure Rate (AFR): 0.48%
  • Power (W) - Seek, Typical: 2.7
  • Power (W) - Idle, Typical: 0.9
  • Temperature (°C) - Operating: 0 to 60
  • Temperature (°C) - Nonoperating: âˆ'40 to 70
  • Shock (Gs) - Operating: 2ms: 350
  • Shock (Gs) - Nonoperating: 1000
  • Acoustics (belsâ€"sound power) - Idle, Typical: 2.2
  • Acoustics (belsâ€"sound power) - Seek, Typical: 2.4
  • Height (in/mm): 0.374/9.5
  • Width (in/mm): 2.75/69.85
  • Depth (in/mm): 3.95/100.35
  • Weight (lb/g): 0.254/115
Seagate Laptop SSHD - hybrid hard drive - 1 TB - SATA 6Gb/s
Hybrid hard drive - internal
1 TB
Flash Memory Capacity
8 GB
NAND Flash Memory Type
Multi-level cell (MLC)
2.5" x 1/8H
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
64 MB
Spindle Speed
5400 rpm
QuietStep, Native Command Queuing (NCQ), Ramp Load
69.85 mm x 100.35 mm x 9.5 mm
115 g
3 years warranty
1 TB
8 GB
2.5" x 1/8H
SATA 6Gb/s
Buffer Size
64 MB
Bytes per Sector
4096
69.85 mm
100.35 mm
9.5 mm
115 g
Performance
Drive Transfer Rate
600 MBps (external)
Seek Time
12 ms (average) / 14 ms (max)
Spindle Speed
5400 rpm
Reliability
Non-Recoverable Errors
1 per 10^14
Start / Stop Cycles
600,000
Expansion & Connectivity
1 x SATA 6 Gb/s - 7 pin Serial ATA
Compatible Bays
1 x 2.5" x 1/8H - internal
Power Consumption
2.7 Watt ( active ) , 0.9 Watt ( idle )
Limited warranty - 3 years
60 °C
Shock Tolerance
350 g @ 2ms
Seagate 1TB Laptop SSHD SATA 6GB/s 64MB 9.5mm Hard Drive - Compatible with PS4 Bundle deal on Seagate 1TB Laptop SSHD SATA 6GB/s 64MB 9.5mm Hard Drive - Compatible with PS4
Including:
CoolerMaster High Performance Thermal Paste 2g CoolerMaster High Performance Thermal Paste 2g worth £4.83 | in stock
Akasa Cable Tidy Kit Akasa Cable Tidy Kit worth £4.20 | in stock
StarTech.com 7 Piece Precision Screwdriver Computer Tool Kit StarTech.com 7 Piece Precision Screwdriver Computer Tool Kit worth £11.61 | in stock
Best Value Duratool Antistatic Wrist Band Best Value Duratool Antistatic Wrist Band worth £3.60 | while stocks last
C2G 1m 7-pin 180° to 90° 1-Device Serial ATA Cable C2G 1m 7-pin 180° to 90° 1-Device Serial ATA Cable worth £3.58 | in stock
£94.51
saving £8.26
Cables (1)
Cables
Including:
£76.76
saving £1.78
Other bundles (2)
Including:
£76.78
saving £1.80
Including:
Intenso 32GB Rainbow Transparent USB Flash Drive Intenso 32GB Rainbow Transparent USB Flash Drive worth £5.48 | in stock
£79.07
saving £1.39
Cables (1)
Cables
8KRV StarTech.com USB 3.0 to 2.5" SATA 6GB/s Hard Drive/SSD Adapter Cable In Stock £12.57
Other bundles (3)
8KRV StarTech.com 2.5in Aluminum USB 3.0 External SATA III SSD Hard Drive Enclosure with UASP for SATA 6 In Stock £18.82
8KRV StarTech.com Dual 2.5" to 3.5" HDD Bracket for SATA Hard Drives - 2 Drive 2.5" to 3.5" Bracket In Stock £7.17
8KRV StarTech.com Dual-bay 2.5" Drive Enclosure In Stock £61.83
Customer reviews
Write a review for the Seagate 1TB Laptop SSHD SATA 6GB/s 64MB 9.5mm Hard Drive - Compatible with PS4 here!
used to replace 7200rpm stock drive macbook pro 2009
Reviewed by Andy. Review Posted 21/04/2014
well worth the money osx mavericks now boots in about 25 secs and because the ssd part of the hdd learns your frequently opened programs it opens my most used apps instantly .
  • Overall 5*
  • Ease of use 5*
  • Value for money 5*
SSHD as 2nd drive in wifes laptop
Reviewed by Allan Morrell. Review Posted 03/10/2013
Installed as 2nd hard drive in wifes packard bell 17" laptop..Mint linux 13 (LTS) 64 bit installed on it..Boots very quickly...System ready to use very quickly after log-in..Opens & closes programs very fast,so system response is enhanced...My own laptop closes Mint linux in about 5 seconds but my wifes closes in less than 4 seconds..I am seriously considering replacing my own hard drive with one of these...Thoroughly recommended!
  • Overall 5*
  • Ease of use 5*
The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
Buy used stock
What is used stock?
Used stock is a great opportunity to bag yourself a bargain. There are many reasons why a product may be classed as used stock ranging from missing manuals or software to simply having been opened or having damaged packaging. Some items may have been repaired under warranty. Rest assured though that all used stock comes with a 6 month warranty and is in good working order. You can find out the exact details about each product using the key below.
Accessories Packaging Functional Software Manuals
Ref: 8KRV 033927
Condition: Customer return - item has been repaired under warranty by the manufacturer
This part of the stock item is not applicable e.g. it might not include accessories or software as standard  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is not applicable e.g. it might not include accessories or software as standard  £54.73
Legend
  • This part of the stock item is present and in good conditionThis part of the stock item is present and in good condition
  • This part of the stock item is not present or functionalThis part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standardThis part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.This item has not been tested.
Capacity: 1TB
Brand: Seagate
Stock Status: Used Stock
Price Range Inc VAT: 50 - 100
