BT.com
Wishlist
Seagate 1TB Laptop SSHD SATA 6GB/s 64MB 9.5mm Hard Drive - Compatible with PS4
Momentus XT SSHD Fuse SSD Speeds & High Capacity!
Delivery
Standard Due date unavailable
9.5mm Design Ideal For PS4 Upgrade
Seagate® Laptop and Laptop Thin SSHDs fuse the lightning speed of SSD with the high capacity of a hard drive. Powered by Seagate Adaptive Memory™ technology, SSHD improves boot times and application speed dramatically, unleashing your system's performance.
  • 1TB, 9.5mm design for maximum capacity laptops
  • Boots up and performs like an SSD
  • Up to 5 times faster than a traditional 5400-RPM HDD
  • Easy laptop upgrade to boost performance and capacity.
SSHDs use Seagate flash management technology to deliver SSD-like performance. Testing consistently shows that Seagate Laptop SSHDs compare favourably to SSDs--without sacrificing capacity.
SSD + HDD - The best of both worlds.
Seagate Laptop SSHDs integrate NAND flash solid-state storage with traditional hard drive storage, creating a laptop drive with the speed of solid state and the capacity of a hard drive.
  • No need to compromise performance over capacity
  • Installs and works like a typical hard drive
  • Unmatched data integrity and reliability by maximising the strengths of both flash and hard drive storage
  • Performance optimised by Seagate Adaptive Memory™ technology
SSHD is affordable.
SSHDs fuse the strength of SSD and HDD into one affordable and powerful device. You do not have to compromise capacity over performance anymore. With an SSHD, you can have it all. It is the latest and most affordable way to maximise every penny you invest in your PC.
Easy, low-cost HDD laptop upgrade: SSHD provides a great way to breath new life into an older laptop computer.
  • Get performance you never thought possible from your old system
  • One of the most cost-effective ways to increase performance in your PC or MAC system.
  • Easy DIY laptop upgrade solutions available
Seagate Adaptive Memory™ technology effectively identifies the most frequently-used data in your computer. This data is stored in the ultra-fast NAND flash memory, which results in blazing fast boot times and a super-responsive experience where you wait less and do more. This technology is constantly working and adapting to the way you work and access information.
PC & Mac Compatible.
Your Seagate® Laptop SSHD or Laptop Thin SSHD is designed to work in any standard laptop system. Unlike other "hyrbrid" solutions, there are no special drivers or software to install and configure. It installs and works just like a hard drive - only faster!
Affordable and reliable SSHD for your laptop.
SSHDs fuse the strength of SSD and HDD into one affordable and powerful device. You'll be surprised at how little you have to pay to get SSD-like performance in your laptop.
And since SSD fuses the strengths of both HDD and SSD technologies, you get the combined reliability of both in a solid state hybrid drive product.
Specification
  • Capacity: 1 TB
  • Interface: SATA 6Gb/s NCQ
  • NAND Type/Size: MLC/8GB
  • DRAM Cache (MB): 64
  • SATA Transfer Rates Supported (Gb/s): 6.0/3.0/1.5
  • Average Data Throughput (MB/s): 100
  • PC Mark Vantage Average HDD Score: 19,838
  • Average Windows 8 Boot Time (sec): <10
  • Seek Average, Read (ms): <12.0
  • Seek Average, Write (ms): <14
  • Heads/Disks: 4/2
  • Bytes per Sector: 4096
  • Head-Rest Method: QuietStepâ„¢ Ramp Load
  • Load/Unload Cycles: 600,000
  • Norecoverable Read Errors per Bits Read, Max: 1 per 10E14
  • Predicted Annualized Failure Rate (AFR): 0.48%
  • Power (W) - Seek, Typical: 2.7
  • Power (W) - Idle, Typical: 0.9
  • Temperature (°C) - Operating: 0 to 60
  • Temperature (°C) - Nonoperating: âˆ'40 to 70
  • Shock (Gs) - Operating: 2ms: 350
  • Shock (Gs) - Nonoperating: 1000
  • Acoustics (belsâ€"sound power) - Idle, Typical: 2.2
  • Acoustics (belsâ€"sound power) - Seek, Typical: 2.4
  • Height (in/mm): 0.374/9.5
  • Width (in/mm): 2.75/69.85
  • Depth (in/mm): 3.95/100.35
  • Weight (lb/g): 0.254/115
Seagate Laptop SSHD - hybrid hard drive - 1 TB - SATA 6Gb/s
Hybrid hard drive - internal
1 TB
Flash Memory Capacity
8 GB
NAND Flash Memory Type
Multi-level cell (MLC)
2.5" x 1/8H
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
64 MB
Spindle Speed
5400 rpm
QuietStep, Native Command Queuing (NCQ), Ramp Load
69.85 mm x 100.35 mm x 9.5 mm
115 g
3 years warranty
1 TB
8 GB
2.5" x 1/8H
SATA 6Gb/s
Buffer Size
64 MB
Bytes per Sector
4096
69.85 mm
100.35 mm
9.5 mm
115 g
Performance
Drive Transfer Rate
600 MBps (external)
Seek Time
12 ms (average) / 14 ms (max)
Spindle Speed
5400 rpm
Reliability
Non-Recoverable Errors
1 per 10^14
Start / Stop Cycles
600,000
Expansion & Connectivity
1 x SATA 6 Gb/s - 7 pin Serial ATA
Compatible Bay
2.5" x 1/8H
Power Consumption
2.7 Watt (active) , 0.9 Watt (idle)
Limited warranty - 3 years
60 °C
Shock Tolerance
350 g @ 2ms
Accessories
£19.66
£7.48
£10.18
StarTech.com Dual-bay 2.5" Drive Enclosure
Quicklinx: B90V | In Stock
£67.62
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
5* used to replace 7200rpm stock drive macbook pro 2009
Reviewed by Andy on 21/04/2014
well worth the money osx mavericks now boots in about 25 secs and because the ssd part of the hdd learns your frequently opened programs it opens my most used apps instantly .
5* SSHD as 2nd drive in wifes laptop
Reviewed by Allan Morrell on 03/10/2013
Installed as 2nd hard drive in wifes packard bell 17" laptop..Mint linux 13 (LTS) 64 bit installed on it..Boots very quickly...System ready to use very quickly after log-in..Opens & closes programs very fast,so system response is enhanced...My own laptop closes Mint linux in about 5 seconds but my wifes closes in less than 4 seconds..I am seriously considering replacing my own hard drive with one of these...Thoroughly recommended!
Scroll to top
