Click to visit BT.com
BT.com
Wishlist
Seagate 1TB Desktop SSHD 7200RPM SATA 6GB/s 64MB 3.5" 8GB SSD Cache
SSD Performance. HDD Capacity. Affordable Price.
5.0*
Quicklinx: 8XSLWS00
Mfr#: ST1000DX001
Form Factor: 3.5" x 1/4H
Type: Hybrid hard drive
Interface Type: Serial ATA-600
Capacity: 1TB
Spin Speed (rpm): 7200rpm
Express delivery Order within the next 20 hours for delivery on Tuesday
£62.89
Essential accessories
Buy a Seagate Desktop SSHD today and receive a Dying Light Season Pass. Once you have bought your product, email duncsdeals@dabs.com with your Name, Email Address and Sales Order Number and you will receive a follow up email within 48 hours with your code.
Performance. Capacity. Affordable Price.
The wait is over for a solid state hybrid drive in a 3.5-inch form factor. The Seagate® Desktop SSHD delivers SSD-like performance and massive capacities at an affordable price. Don't waste time and money on a dual drive solution to get the high performance and capacity you demand for:
  • Desktop PCs
  • Workstations
  • Direct-attached storage (DAS) devices
The Seagate® Desktop SSHD is here with breakthrough technology that identifies and stores to flash only your most frequently used data. You can boot up and launch applications faster while still having the massive capacities you need for everything else. Choose performance and capacity with 8GB of MLC NAND flash and up to 2TB of HDD capacity. 3-year limited warranty.
Why choose the Desktop SSHD?
  • Simple. An all-in-one storage solution
  • Performance. SSD-like performance to give you the boost you crave
  • Capacity. The capacity you need--up to 2TB
  • Price. An affordable price that makes sense
  • The first solid state hybrid drive (SSHD) in a 3.5-inch form factor
  • Boots up and performs like an SSD1
  • SATA 6Gb/s with NCQ for interface speed
  • Faster than a traditional HDD1
  • All-in-one design for simplicity and ease of installation
  • Installs and operates like a standard hard drive: cross-platform, no drivers or additional software required
  • Massive 1TB or 2TB capacities combined with SSD-like performance1
  • Backed by a 3-year limited warranty
Solid State Drive Technology Inside Your SSHD
SSHD technology uses the right amount of ultra-fast NAND flash (the same type used in SSDs) to increase system performance. Seagate's Adaptive Memory ™ technology effectively identifies the most frequently-used data and stores it in the NAND flash. The results give you greatly improved boot times, application loads and overall system responsiveness.
Get it all - desktop speed and capacity.
With SSHD technology, there is no need to trade capacity for high performance. The Seagate® Desktop SSHD is available in 1TB and 2TB capacities, giving you plenty of space for all of your digital content. Store up to 1,000 video games, 2,000 hours of video, 500 HD DVDs, 640,000 digital photos, or over 33,000 hours of mp3 music files.* *Quantitative usage examples for various applications are for illustrative purposes. Actual quantities will vary based on several factors, including file size, file format, features and application software.
Affordable and reliable SSHD for your desktop
SSHDs fuse the strength of SSD and HDD into one affordable and powerful device. You'll be surprised at how little you have to pay to get SSD-like performance in your desktop system.
And since SSD fuses the strengths of both HDD and SSD technologies, you get the combined reliability of both in a solid state hybrid drive product.
Easy, Low-cost HDD Desktop Upgrade
SSHD provides a great way to breath new life into an older desktop computer.
  • Get performance you never thought possible from your old system
  • One of the most cost-effective ways to increase the performance of your system.
Spec
  • Capacity: 1TB
  • NAND Type/Size: MLC/8GB
  • Interface: SATA 6Gb/s NCQ
  • Cache 64MB
  • Average Data Rate, Read, Avg All Zones up to 156MB/s
  • Average Data Rate From NAND Media up to 190MB/s
  • Operating Temperature: 0°C to 60°C
Seagate Desktop SSHD - hybrid hard drive - 1 TB - SATA 6Gb/s
Hybrid hard drive - internal
1 TB
Flash Memory Capacity
8 GB
NAND Flash Memory Type
Multi-level cell (MLC)
3.5" x 1/4H
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
64 MB
Native Command Queuing (NCQ), SSHD
101.6 mm x 146.99 mm x 20.17 mm
400 g
Microsoft Certification
Compatible with Windows 7
3 years warranty
1 TB
8 GB
3.5" x 1/4H
SATA 6Gb/s
Buffer Size
64 MB
Bytes per Sector
4096
101.6 mm
146.99 mm
20.17 mm
400 g
Performance
Drive Transfer Rate
600 MBps (external)
Seek Time
8.5 ms (average)
Reliability
Non-Recoverable Errors
1 per 10^14
Start / Stop Cycles
300,000
Expansion & Connectivity
1 x SATA 6 Gb/s - 7 pin Serial ATA
Compatible Bays
1 x 3.5" x 1/4H - internal
Power Consumption
5.9 Watt ( active ) , 0.9 Watt ( idle )
3 years warranty
Service & Support Details
Limited warranty - 3 years
60 °C
Seagate 1TB Desktop SSHD 7200RPM SATA 6GB/s 64MB 3.5 Bundle deal on Seagate 1TB Desktop SSHD 7200RPM SATA 6GB/s 64MB 3.5" 8GB SSD Cache
Including:
CoolerMaster High Performance Thermal Paste 2g CoolerMaster High Performance Thermal Paste 2g worth £4.83 | in stock
Akasa Cable Tidy Kit Akasa Cable Tidy Kit worth £4.62 | in stock
StarTech.com 7 Piece Precision Screwdriver Computer Tool Kit StarTech.com 7 Piece Precision Screwdriver Computer Tool Kit worth £11.61 | in stock
Best Value Duratool Antistatic Wrist Band Best Value Duratool Antistatic Wrist Band worth £3.60 | while stocks last
C2G 1m 7-pin 180° to 90° 1-Device Serial ATA Cable C2G 1m 7-pin 180° to 90° 1-Device Serial ATA Cable worth £3.58 | in stock
£82.42
saving £8.68
Cables (1)
Cables
Including:
£64.67
saving £1.78
Options (2)
Including:
£64.69
saving £1.80
Including:
Corsair Flash Voyager Slider - 32GB - USB 3.0 Corsair Flash Voyager Slider - 32GB - USB 3.0 worth £9.88 | in stock
£72.88
8XSL StarTech.com 3.5in Black USB 3.0 External SATA III Hard Drive Enclosure with UASP for SATA 6 Gbps In Stock £33.72
8XSL StarTech.com USB 3.0/eSATA Dual 3.5" SATA III Hard Drive External RAID Enclosure w/ UASP - Black In Stock £79.81
8XSL StarTech.com 3 Bay Aluminum Trayless Hot Swap Mobile Rack Backplane for 3.5in SAS II/SATA III In Stock £76.44
Resources
The following resources are available for the Seagate 1TB Desktop SSHD 7200RPM SATA 6GB/s 64MB 3.5" 8GB SSD Cache
Customer reviews
Write a review for the Seagate 1TB Desktop SSHD 7200RPM SATA 6GB/s 64MB 3.5" 8GB SSD Cache here!
segate
Reviewed by Anonymous Review Posted 18/09/2014
great
  • Overall 5*
  • Ease of use 5*
  • Value for money 5*
Reviewed by Dave. Review Posted 02/03/2015
I bought this drive to replace a smaller drive which was slower as well, this new one is much faster and quieter than the previous one. the pc boots much better and I think that's due to the built in SSD part, I just cloned the entire drive and resized the partition so no spending all day reinstalling everything , I would recommend this drive as a good buy at a great price
  • Overall 5*
  • Ease of use 5*
sshd drive
Reviewed by Anonymous Review Posted 16/09/2014
I received this drive very quickly and was amazed at how easy it was to install, the difference in speed is fantastic and would recommend to anyone.
  • Overall 5*
  • Ease of use 5*
Great drive at a great price
Reviewed by Anonymous Review Posted 07/02/2014
This is a great compromise between speed and storage capacity. Nice quiet drive. Very pleased.
  • Overall 5*
  • Ease of use 5*
Highly Recommended
Reviewed by Chris. Review Posted 09/04/2016
2 in one ! a Hybrid of both SSD and HDD drive with an SSD for speed with a HDD hanging on the back with massive storage.
  • Overall 5*
  • Ease of use 5*
Nice fast Hybrid but only formated at 931GB instead of 1024GB!
Reviewed by Ben Peers. Review Posted 05/04/2014
Great Hybrid drive. I have noticed a significant increase in boot time, game load times and even a small boost of FPS in the games installed on the hybrid drive. Altho I am confused as my old WD Caviar SATA3 6GB/S 500GB, gave a windows index score of 5.9 and nothing has changed since I reinstalled windows on the new drive and placed the old 500GB disk as the 'slave' altho with SATA this is kinda irrelevant anyway. Also as in title windows 7 installer only let me use this drive as it seemed to be pre formatted at 931GB. This sounds a little petty but for a 1TB drive id expect it to atleast meet the standards of what 1 Terabyte means. Overall its a new appreciated piece of hardware for my gaming PC altho it did not change my windows index score as everything else is between 7.5-7.7 whilst the hybrid remains 5.9. BT did their part well with standard delivery by RM within 3 days of dispatch order, came on 2nd or 3rd day :)
  • Overall 4*
  • Ease of use 5*
Windows index score 5.9 and 931 GB instead of 1024 ?
Reviewed by S.Scott. Review Posted 22/11/2014
Id also agree with another reviewer ( Ben Peers ) i could write the exact same review actually because my experience is more or less the same ! this Seagate SSHD gets a windows index score of 5.9 the same as my Western Digital Scorpio Blue hard drive dated 2009 5400rpm i would expect the new drive to have a higher index score ? i mabe using the wrong device driver for this drive i will try Seagate web page for SSHD drive support ! I should state that the speed is better overall on my PC the confusion is mainly over the Windows index scores !
  • Overall 4*
  • Ease of use 5*
The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
Capacity: 1TB
Brand: Seagate
Price Range Inc VAT: 50 - 100
