Click to visit BT.com
BT.com
Wishlist
Seagate 1TB Constellation ES 7200RPM 3.5" SAS 16MB
Quicklinx: 7NR7WS00
Mfr#: ST1000NM0001
Essential accessories
Constellation ES is the fourth generation 3.5-inch drive for enterprise 7200-rpm environments enabling cost-effective, highly efficient enterprise storage with highest capacities, best-in-class reliability, leading performance and optimized power and cooling. With its lowest power consumption and highest temperature tolerance, it optimizes chassis performance in tiered storage solutions. The only drive offering a choice of traditional 3Gbps enterprise SATA interface for seamless enterprise integration or the industry leading 6Gbps SAS enterprise interface for a more reliable, scalable and sustainable high performance enterprise solution.
Constellation ES drives offer high capacity at 2TB while providing enterprise robustness for Tier 2/nearline environments. They are differentiated from 3.5-inch desktop drives by offering enterprise-class reliability and superior data integrity with a UER of 1E10-15. Enterprise-class rotational vibration tolerance provides robust protection from chassis and fan vibrations. The drives are offered with either a 3Gbps SATA interface or a 6Gbps SAS 2.0 interface for superior data protection at industry-leading speeds.
Seagate Constellation ES ST1000NM0001 - hard drive - 1 TB - SAS 6Gb/s
Hard drive - internal
1 TB
3.5" x 1/3H
SAS 6Gb/s
Data Transfer Rate
600 MBps
Spindle Speed
7200 rpm
Ramp Load, dual processor, PowerChoice, Protection Information (PI)
10.2 cm x 14.7 cm x 2.6 cm
0.64 kg
Microsoft Certification
Compatible with Windows 7
5 years warranty
1 TB
3.5" x 1/3H
SAS 6Gb/s
10.2 cm
14.7 cm
2.6 cm
0.64 kg
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
150 MBps
Seek Time
8.5 ms (average)
Spindle Speed
7200 rpm
Reliability
MTBF
1,200,000 hours
Non-Recoverable Errors
1 per 10^15
Start / Stop Cycles
300,000
Expansion & Connectivity
2 x SAS 6Gb/s
Compatible Bays
1 x internal - 3.5" x 1/3H
5 years warranty
Service & Support Details
Limited warranty - 5 years
5 °C
60 °C
Shock Tolerance
70 g @ 2ms (operating) / 350 g @ 2ms (non-operating)
Vibration Tolerance
0.5 g @ 5-500 Hz (operating) / 2 g @ 10-500 Hz (non-operating)
