Click to visit BT.com
BT.com
Wishlist
Seagate 1TB Barracuda SATA 6Gb/s 64MB 7200RPM 3.5" Hard Drive
4.0*
Quicklinx: 7XD5WS00
Mfr#: ST1000DM003
Form Factor: 3.5" x 1/4H
Type: Hard drive
Interface Type: Serial ATA-600
Capacity: 1TB
Spin Speed (rpm): 7200rpm
Express delivery Order within the next hour for delivery tomorrow
More than 50 in stock
£43.38
Essential accessories
The Seagate Desktop HDD is the one hard drive for all your desktop applications. One drive for every need, supported by 30 years of trusted performance, reliability and simplicity.
Seagate Desktop HDD ST1000DM003 - hard drive - 1 TB - SATA 6Gb/s
Hard drive - internal
1 TB
3.5" x 1/4H
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
64 MB
Spindle Speed
7200 rpm
Native Command Queuing (NCQ), Perpendicular Magnetic Recording (PMR), Seagate OptiCache technology, Seagate AcuTrac technology, Seagate SmartAlign technology
101.6 mm x 146.99 mm x 20.17 mm
400 g
Microsoft Certification
Compatible with Windows 7
2 years warranty
1 TB
3.5" x 1/4H
SATA 6Gb/s
Buffer Size
64 MB
Bytes per Sector
4096
101.6 mm
146.99 mm
20.17 mm
400 g
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
210 MBps (read) / 156 MBps (write)
Seek Time
9.5 ms (max)
Spindle Speed
7200 rpm
Reliability
Non-Recoverable Errors
1 per 10^14
Load / Unload Cycles
300,000
Expansion & Connectivity
1 x SATA 6 Gb/s - 7 pin Serial ATA
Compatible Bays
1 x 3.5" x 1/4H - internal
Power Consumption
5.9 Watt ( active ) , 3.36 Watt ( idle ) , 0.63 Watt ( stand by ) , 0.63 Watt ( sleep )
RoHS
60 °C
Seagate 1TB Barracuda SATA 6Gb/s 64MB 7200RPM 3.5 Bundle deal on Seagate 1TB Barracuda SATA 6Gb/s 64MB 7200RPM 3.5" Hard Drive
Including:
CoolerMaster High Performance Thermal Paste 2g CoolerMaster High Performance Thermal Paste 2g worth £4.83 | in stock
Akasa Cable Tidy Kit Akasa Cable Tidy Kit worth £4.20 | in stock
StarTech.com 7 Piece Precision Screwdriver Computer Tool Kit StarTech.com 7 Piece Precision Screwdriver Computer Tool Kit worth £11.61 | in stock
Best Value Duratool Antistatic Wrist Band Best Value Duratool Antistatic Wrist Band worth £3.60 | while stocks last
C2G 1m 7-pin 180° to 90° 1-Device Serial ATA Cable C2G 1m 7-pin 180° to 90° 1-Device Serial ATA Cable worth £3.58 | in stock
£62.91
saving £8.26
Cables (1)
Cables
Including:
£45.16
saving £1.78
Other bundles (2)
Including:
£45.18
saving £1.80
Including:
Intenso 32GB Rainbow Transparent USB Flash Drive Intenso 32GB Rainbow Transparent USB Flash Drive worth £5.48 | in stock
£47.47
saving £1.39
7XD5 StarTech.com 3.5in Black USB 3.0 External SATA III Hard Drive Enclosure with UASP for SATA 6 Gbps In Stock £33.72
7XD5 StarTech.com USB 3.0/eSATA Dual 3.5" SATA III Hard Drive External RAID Enclosure w/ UASP - Black In Stock £79.81
7XD5 StarTech.com 3 Bay Aluminum Trayless Hot Swap Mobile Rack Backplane for 3.5in SAS II/SATA III In Stock £76.44
Customer reviews
Write a review for the Seagate 1TB Barracuda SATA 6Gb/s 64MB 7200RPM 3.5" Hard Drive here!
Quick and Quiet (Great Drive)
Reviewed by S Singh. Review Posted 19/03/2012
I've used seagate barracuda drives for many years. Always found them totally reliable and virtually silent in operation. Its been a few years since I last built a system (before sata came out), but I'm happy to say that Seagate still have what it takes with their barracuda drives. Read/write speeds (Test done after the drive was newly formatted and contained no data. Speeds according to Bart's Stuff Test) Sequential write: 146MB/s Sequential read: 130MB/s Pros: After a trouble-free set up and a day of use, I've had no problems with this huge, fast drive. *Well worth purchasing*
  • Overall 5*
  • Ease of use 5*
  • Value for money 5*
  • Overall 5*
  • Ease of use 5*
Quality product, great price
Reviewed by Bergamot Eng.. Review Posted 23/09/2013
Quiet, does the job perfectly.
I went away from Seagate for a few years as I thought Western Digital were better for quality and value.
As the WD of this Seagate drive was more than 30 percent more expensive than this one when I bought it (August 2013) I gave it a go. I don't regret the buy. We'll see how it goes in the long run but I am quite confident it will be fine.
  • Overall 5*
  • Ease of use 5*
Great Drive
Reviewed by I Mullan. Review Posted 05/03/2013
Excellent, fast, quite drive. Well worth the money.
  • Overall 5*
  • Ease of use 5*
Fast & Quiet
Reviewed by Gavin. Review Posted 15/03/2014
Added this to my wife's computer 8 months ago.
Very fast and quiet. have always used Barracuda Drives - see no reason to change.
  • Overall 5*
  • Ease of use 5*
Seagate 1TB BarracudaSATA 6gb/s 64MB 7200RPM Harad Drive
Reviewed by Sam. Review Posted 03/02/2014
Good Product but very noisy
  • Overall 4*
  • Ease of use 5*
Not 1TB
Reviewed by Ian N Randall. Review Posted 06/08/2013
1TB = 1024GB
Fitted to machine but reads as only 931gb
  • Overall 3*
  • Ease of use 5*
Another failure
Reviewed by Chris. Review Posted 10/01/2015
I bought this for use in my Sky box. Now 2 Years and ONE month later it has totally died. The Sky box won't see it neither will the PC.
From now on I'm going with Western Digital Red drives and avoiding Seagate.
The only good thing was that it was in the Sky box not a PC as the loss of data would have been much worse.
  • Overall 1*
  • Ease of use 5*
  • Value for money 2*
Failed
Reviewed by Anonymous Review Posted 03/11/2013
Drive died after 14 months. Out of warranty.
  • Overall 1*
  • Ease of use 5*
  • Value for money 1*
The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
Type: Hard drive
Capacity: 1TB
Brand: Seagate
Price Range Inc VAT: 0 - 50
