BT.com
Wishlist
Seagate 1TB Barracuda SATA 6Gb/s 64MB 7200RPM 3.5" Hard Drive
Seagate 1TB Barracuda SATA 6Gb/s...
£42.90
Hurry, only 1 left in stock!
£42.90
Add to wishlist
Delivery
Standard 1-3 working days
Express Delivered on Tuesday
Express Delivery
  • 00 h
  • 00 m
  • 00 s
The Seagate Desktop HDD is the one hard drive for all your desktop applications. One drive for every need, supported by 30 years of trusted performance, reliability and simplicity.
Seagate Desktop HDD ST1000DM003 - hard drive - 1 TB - SATA 6Gb/s
Hard drive - internal
1 TB
3.5" x 1/4H
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
64 MB
Spindle Speed
7200 rpm
Native Command Queuing (NCQ), Perpendicular Magnetic Recording (PMR), Seagate OptiCache technology, Seagate AcuTrac technology, Seagate SmartAlign technology
101.6 mm x 146.99 mm x 20.17 mm
400 g
Microsoft Certification
Compatible with Windows 7
2 years warranty
1 TB
3.5" x 1/4H
SATA 6Gb/s
Buffer Size
64 MB
Bytes per Sector
4096
101.6 mm
146.99 mm
20.17 mm
400 g
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
210 MBps (read) / 156 MBps (write)
Seek Time
9.5 ms (max)
Spindle Speed
7200 rpm
Reliability
Non-Recoverable Errors
1 per 10^14
Load / Unload Cycles
300,000
Expansion & Connectivity
1 x SATA 6 Gb/s - 7 pin Serial ATA
Compatible Bay
3.5" x 1/4H
Power Consumption
5.9 Watt (active) , 3.36 Watt (idle) , 0.63 Watt (standby) , 0.63 Watt (sleep)
RoHS
60 °C
Cables - Cables
Seagate 1TB Barracuda SATA 6Gb/s 64MB 7200RPM 3.5" Hard...
£42.90
Save 50% On This 1m SATA Cable When Bought With This Item
Save £3.19
£46.09
Accessories
£37.15
£74.98
£84.06
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
5* Quick and Quiet (Great Drive)
Reviewed by S Singh on 19/03/2012
I've used seagate barracuda drives for many years. Always found them totally reliable and virtually silent in operation. Its been a few years since I last built a system (before sata came out), but I'm happy to say that Seagate still have what it takes with their barracuda drives. Read/write speeds (Test done after the drive was newly formatted and contained no data. Speeds according to Bart's Stuff Test) Sequential write: 146MB/s Sequential read: 130MB/s Pros: After a trouble-free set up and a day of use, I've had no problems with this huge, fast drive. *Well worth purchasing*
5* Quality product, great price
Reviewed by Bergamot Eng. on 23/09/2013
Quiet, does the job perfectly.
I went away from Seagate for a few years as I thought Western Digital were better for quality and value.
As the WD of this Seagate drive was more than 30 percent more expensive than this one when I bought it (August 2013) I gave it a go. I don't regret the buy. We'll see how it goes in the long run but I am quite confident it will be fine.
5* Great Drive
Reviewed by I Mullan on 05/03/2013
Excellent, fast, quite drive. Well worth the money.
5* Fast & Quiet
Reviewed by Gavin on 15/03/2014
Added this to my wife's computer 8 months ago.
Very fast and quiet. have always used Barracuda Drives - see no reason to change.
4* Seagate 1TB BarracudaSATA 6gb/s 64MB 7200RPM Harad Drive
Reviewed by Sam on 03/02/2014
Good Product but very noisy
3* Not 1TB
Reviewed by Ian N Randall on 06/08/2013
1TB = 1024GB
Fitted to machine but reads as only 931gb
1* Another failure
Reviewed by Chris on 10/01/2015
I bought this for use in my Sky box. Now 2 Years and ONE month later it has totally died. The Sky box won't see it neither will the PC.
From now on I'm going with Western Digital Red drives and avoiding Seagate.
The only good thing was that it was in the Sky box not a PC as the loss of data would have been much worse.
1* Failed
Reviewed by Anonymous on 03/11/2013
Drive died after 14 months. Out of warranty.
Scroll to top
