BT.com
Wishlist
Sapphire Technology AMD Radeon RX470 NITRO+ 8GB GDDR5 PCIe3.0 Graphics Card
Delivery
Standard Due date unavailable
SAPPHIRE NITRO+ Radeon™ RX 470 8G D5
The SAPPHIRE NITRO+ Radeon™ RX 470 is the next big thing in mainstream 1080p gaming.Custom-designed SAPPHIRE NITRO+ models come with an energy-efficient foundation of Polaris chip and a slew of added features in both cooling and aesthetics already seen in the NITRO+ RX 480 model. Compared to the previous R9 270 generation GPU, playing on the RX 470 means performance up to 2.4x better in latest titles such as Total War: WARHAMMER or DOOM. Engineered with power savings in mind, the 4th generation Graphics Core Next chip maintains the typical board power of around 170 W. Polaris-powered GPU-s also mean improved geometry engine, increased cache and native asynchronous shaders for unmatched efficiency in DirectX 12.
The SAPPHIRE NITRO+ Radeon™ RX 470 cards all come equipped with 2048 GCN-based stream processors and 256-bit memory interface. The 8 GB model has a GPU boost clock of 1260 MHz (1121 MHz base) and memory clocked at 2000 MHz for 8 Gbps throughput.
AMD XConnect™ Technology
Plug in and game on with AMD XConnect technology.
Now it’s easier than ever to connect and use an external Radeon™ graphics card. With AMD XConnect™ technology, external GPU enclosures configured with Radeon™ Graphics can easily connect and disconnect to a compatible ultrathin notebook or 2-in 1 over Thunderbolt™ 3 at any time, just like a USB flash drive—a first for external GPUs!
Virtual Super Resolution
Virtual Super Resolution (VSR) is an AMD feature that is game and engine agnostic to simulate Super-Sampling Anti-Aliasing (SSAA) in games that do not have native SSAA support. VSR can also be used in conjunction with other native in-game anti-aliasing for even more game graphics-setting control. VSR allows games to render at higher resolutions (up to 4K; see the ‘Virtual Super Resolution Support’ table, below) and then rescales them down to a lower native display resolution. Using this, you can get quality that rivals up to 4K, even on a 1080p display while playing your favorite games.
HDR Ready
High Dynamic Range (HDR) is a state-of-the-art technology for gamers and cinephiles that care deeply about the display quality of their TV or monitor. Modeled after the acuity of human vision, HDR vastly expands the range of colors and contrast ratios that can be shown by compatible displays. HDR-ready games and movies played on an HDR display appear strikingly sharp, colorful, and vivid, with enhanced contrast and sophisticated nuance compared to even the most stunning SDR content.
NITRO Boost
The new NITRO Boost switch increases the boost clock and power limit for higher performance to unleash the gaming performance of the card.
Planning to overclock or looking for maximum performance? SAPPHRE NITRO cards come with an 8 pin power connector to plug in and enable Nitro Boost.
VR Friendly
The SAPPHIRE NITRO Gaming Series cards come with Dual HDMI ports, specifically designed to work with VR. By having two HDMI ports, you can have both an HD monitor and cutting-edge VR headset running at the same time.
The ports are HDMI 2.0b, the latest update, with an 18Gbps bandwidth, up to 32 audio channels, and is able to support 4K 50/60 resolutions like 2160P, whilst remaining entirely backwards compatible with older HDMI specifications.
Sapphire NITRO+ RX 470 - graphics card - Radeon RX 470 - 8 GB
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
AMD Radeon RX 470
8 GB GDDR5
Core Clock
1260 MHz
Stream Processors
2048
Memory Interface
256-bit
Max Resolution
3840 x 2160
Max Resolution Details
DVI: 2560 x 1600 / DisplayPort: 3840 x 2160 / HDMI: 3840 x 2160
Max Monitors Supported
5
2 x HDMI , 2 x DisplayPort , DVI-D
API Supported
DirectX 12, OpenGL 4.5, OpenCL 2.0
4.1 cm x 24 cm x 12.5 cm
Package Type
Lite retail
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
AMD Radeon RX 470
Core Clock
1260 MHz
Stream Processors
2048
Process Technology
14 nm
Max Resolution
3840 x 2160
5
API Supported
Dual Bios, AMD Eyefinity Technology, AMD CrossFireX Technology, Dolby True HD support, DTS-HD Master Audio support, Shader Model 5.0, Dual-X cooler, Graphics Core Next (GCN), Dual ball Bearing Fan, UEFI BIOS, AMD TrueAudio Technology, factory overclocked, FreeSync Technology, AMD LiquidVR Technology, Virtual Super Resolution (VSR), Frame Rate Target Control(FRTC), AMD XConnect Technology, NITRO Fan Check, NITRO Quick Connect system, NITRO Glow RGB LED, NITRO CoolTech, NITRO Free Flow, NITRO Boost, Intelligent Fan Control (IFC) III, Black Diamond Chokes 4
Size
8 GB
GDDR5 SDRAM
Bus Width
256-bit
Microsoft Windows 7 / 10
Required Power Supply
500 W
Additional Requirements
CD-ROM, 8 pin PCI Express power connector
225 Watt
4.1 cm
24 cm
12.5 cm
Package Type
Lite retail
Scroll to top
