BT.com
Wishlist
Sapphire Technology AMD Radeon RX460 NITRO+ 4GB GDDR5 PCIe3.0 Graphics Card
Delivery
Standard Due date unavailable
SAPPHIRE NITRO Radeon™ RX 460 4G D5
For online gamers playing most popular titles such as Counter-Strike: Global Offensive, League of Legends or Overwatch SAPPHIRE Technology introduces the new inexpensive SAPPHIRE NITRO Radeon™ RX 460 graphics card. Featuring the latest power-efficient Polaris chip and making no compromises in cooling, the new budget king of the Radeon rebellion is an affordable upgrade to latest graphics technology.
Designed to perform great in massively popular online titles, the SAPPHIRE NITRO Radeon™ RX 460 promises minimum input lag and over 100 frames per second in Dota 2 or Rocket League in 1080p. Performance up to 30% better than R7 260X is the result of factory-overclocked 4th generation GCN core. The card features 896 stream processors with a boost clock up to 1250 MHz as well as 4 GB of GDDR5 video memory on 128-bit interface and clocked at 1750 MHz (7 Gbps effective speed).
AMD XConnect™ Technology
Plug in and game on with AMD XConnect technology.
Now it’s easier than ever to connect and use an external Radeon™ graphics card. With AMD XConnect™ technology, external GPU enclosures configured with Radeon™ Graphics can easily connect and disconnect to a compatible ultrathin notebook or 2-in 1 over Thunderbolt™ 3 at any time, just like a USB flash drive—a first for external GPUs!
HDR Ready
High Dynamic Range (HDR) is a state-of-the-art technology for gamers and cinephiles that care deeply about the display quality of their TV or monitor. Modeled after the acuity of human vision, HDR vastly expands the range of colors and contrast ratios that can be shown by compatible displays. HDR-ready games and movies played on an HDR display appear strikingly sharp, colorful, and vivid, with enhanced contrast and sophisticated nuance compared to even the most stunning SDR content.
Virtual Super Resolution
Virtual Super Resolution (VSR) is an AMD feature that is game and engine agnostic to simulate Super-Sampling Anti-Aliasing (SSAA) in games that do not have native SSAA support. VSR can also be used in conjunction with other native in-game anti-aliasing for even more game graphics-setting control. VSR allows games to render at higher resolutions (up to 4K; see the ‘Virtual Super Resolution Support’ table, below) and then rescales them down to a lower native display resolution. Using this, you can get quality that rivals up to 4K, even on a 1080p display while playing your favorite games.
Dual-X Cooling
SAPPHIRE's acclaimed Dual-X Cooling is powered by two massive yet silent fans and state-of-the-art radiator design. The new form of our 95mm blades mean greater airflow and superior heatsink coverage at lower noise compared to standard cooling designs.
These feature dual ball bearing fans, which have an 85% longer lifespan than sleeve bearings in our tests.
AMD Freesync technology
No stuttering. No tearing. Just gaming.
AMD FreeSync™ technology allows a compatible graphics card and monitor to dynamically change frame rates for the optimum display quality without tearing or stuay.
Industry-Standard Displayport
Freesync uses industry-standard displayport Adaptive-Sync Eliminates screen tearing without all the usual lag and latency
• Synchronizes the refresh rate of a compatible monitor to the frame rate of your content, however much it varies
• Monitor partners are validating with drivers from AMD now
Sapphire NITRO RX 460 OC - graphics card - Radeon RX 460 - 4 GB
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
AMD Radeon RX 460
4 GB GDDR5
Core Clock
1250 MHz
Stream Processors
896
Memory Interface
128-bit
Max Resolution
3840 x 2160
Max Resolution Details
DVI (Dual-Link): 2560 x 1600 at 60 Hz/ DisplayPort: 3840 x 2160 at 60 Hz/ HDMI: 3840 x 2160 at 60 Hz
Max Monitors Supported
3
HDMI , DisplayPort , DVI-D (dual link)
API Supported
DirectX 12, OpenGL 4.5, OpenCL 2.0
3.8 cm x 22.1 cm x 12.3 cm
Package Type
Lite retail
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
AMD Radeon RX 460
Core Clock
1250 MHz
Stream Processors
896
Process Technology
14 nm
Max Resolution
3
API Supported
Dual Slot Fan Cooler, Sapphire Black Diamond Choke, High dynamic-range (HDR) rendering, AMD Eyefinity Technology, AMD CrossFireX Technology, Dolby True HD support, DTS-HD Master Audio support, Shader Model 5.0, Dual-X cooler, Graphics Core Next (GCN), Dual ball Bearing Fan, UEFI BIOS, AMD TrueAudio Technology, FreeSync Technology, Virtual Super Resolution (VSR), Frame Rate Target Control(FRTC), AMD XConnect Technology, NITRO Fan Check, NITRO Quick Connect system
Size
4 GB
GDDR5 SDRAM
Bus Width
128-bit
Microsoft Windows 7, Windows 10
Required Power Supply
450 W
Additional Requirements
CD-ROM, 6 pin PCI Express power connector
150 Watt
3.8 cm
22.1 cm
12.3 cm
Package Type
Lite retail
Scroll to top
