BT.com
Wishlist
Sapphire Technology AMD Radeon R9 Nano 4GB HBM PCIe Graphics Card
Delivery
Standard Due date unavailable
The AMD Radeon R9 Nano graphics card is AMD's most innovative and advanced GPU to date, delivering 4096-bit High-Bandwidth Memory (HBM), the highest memory bandwidth ever in a GPU, engineered for 4K and VR gaming - in a revolutionary small form factor graphics card - the ultimate GPU for Mini-ITX PC supremacy. Experience DirectX 12 featuring async shaders and multi-threaded command buffer recording as well as support for OpenGL 4.5 and Vulkan APIs. Push your gameplay to the max and achieve scorchingly-fast framerates at ultra settings by adding up to four GPUs with AMD CrossFire multi-GPU technology.
Sapphire RADEON R9 Nano - graphics card - Radeon R9 NANO - 4 GB
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
AMD Radeon R9 NANO
4 GB HBM
Core Clock
1000 MHz
Stream Processors
4096
Effective Memory Clock
500 MHz
Memory Interface
4096-bit
Max Resolution
4096 x 2160
Max Monitors Supported
4
HDMI , 3 x DisplayPort
API Supported
OpenCL 1.2, DirectX 12, OpenGL 4.5, Vulkan
Package Type
Retail
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
AMD Radeon R9 NANO
Core Clock
1000 MHz
Stream Processors
4096
Process Technology
28 nm
Max Resolution
4096 x 2160
4
API Supported
AMD Eyefinity Technology, AMD HD3D Technology, AMD CrossFireX Technology, AMD PowerTune technology, AMD Unified Video Decoder (UVD) 3, Graphics Core Next (GCN), AMD ZeroCore Power technology, AMD TrueAudio Technology, FreeSync Technology, AMD LiquidVR Technology, Virtual Super Resolution (VSR), Frame Rate Target Control(FRTC)
Size
4 GB
HBM
Effective Clock Speed
500 MHz
Bus Width
4096-bit
Microsoft Windows XP / Vista / 7 / 8 / 8.1 / 10
Additional Requirements
CD-ROM, 8 pin PCI Express power connector
175 Watt
Package Type
Retail
Scroll to top
