BT.com
Wishlist
Sapphire Technology AMD Radeon R9 Fury X Graphics 4GB HBM PCIe3.0
Delivery
Standard Due date unavailable
Like nothing you’ve seen before
The AMD Radeon™ R9 Fury X graphics card is the world’s first total solution GPU with AMD-pioneered High-Bandwidth Memory (HBM) on-chip delivering extreme 4K performance and unbelievably "real" VR experiences.
Don’t just upgrade. Revolutionize with the AMD Radeon™ R9 Fury X graphics card.
AMD High Bandwidth Memory
- High-Bandwidth Memory with more than 3x the bandwidth per watt over GDDR5 along with a 4096-bit memory interface - the highest AMD GPU memory bandwidth ever.
- Sleek industrial styling including GPU Tach activity indicator and LED illumination all in a compact 7.5-inch card that’s all about raw graphics power.
- Powerful performance, bleeding-edge technology, liquid-cooled, whisper-quiet and future-ready for extreme 4K and VR gaming.
Redefine reality with AMD LiquidVR™ technology.
- Liquid-smooth images with high frame rates for a definitive VR experience.
- Get comfortable with low-latency head tracking.
- Designed for plug-and-play headset compatibility.
Enjoy the View in 4K.
- Command the competition at 4K resolution and beyond, fueled by a 4096-bit high-bandwidth memory interface for extreme performance and power efficiency.
- Take advantage of full support for DirectX® 12, Vulkan™, OpenGL® 4.5 and Mantle.
- Experience the smoothest gameplay without frame-tearing or stuttering with an AMD Eyefinity 3x1, using 1440p FreeSync™-enabled monitors for a massive 6K gameplay "surround view" panorama.
Sapphire RADEON R9 FURY X - graphics card - Radeon R9 Fury X - 4 GB
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
4 GB HBM
Core Clock
1050 MHz
Stream Processors
4096
Effective Memory Clock
500 MHz
Memory Interface
4096-bit
Max Resolution
4096 x 2160
Max Resolution Details
DisplayPort: 4096 x 2160 / HDMI: 4096 x 2160
Max Monitors Supported
4
HDMI , 3 x DisplayPort , DVI - with adapter
API Supported
Mantle, DirectX 12, OpenGL 4.5, OpenCL 2.0, Vulkan
4 cm x 19.5 cm x 11 cm
Package Type
Retail
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
Core Clock
1050 MHz
Stream Processors
4096
Process Technology
28 nm
Max Resolution
4096 x 2160
4
API Supported
Dual Bios, AMD Eyefinity Technology, AMD HD3D Technology, AMD CrossFireX Technology, AMD PowerTune technology, Shader Model 5.0, Graphics Core Next (GCN), AMD ZeroCore Power technology, cutting-edge integrated display support, UEFI BIOS, AMD TrueAudio Technology, AMD Quad CrossFireX Technology, FreeSync Technology, AMD LiquidVR Technology, Virtual Super Resolution (VSR), AMD Water Cooling Technology, AMD XDMA CrossFire Technology, HDCP
Size
4 GB
HBM
Effective Clock Speed
500 MHz
Bus Width
4096-bit
Linux, Microsoft Windows 7 / 8 / 8.1 / 10
Min RAM Size
8 GB
Required Power Supply
750 W
Additional Requirements
CD-ROM, 2 x 8 pin PCI Express power connector
1 x HDMI cable - 1.8 m , 1 x DisplayPort-DVI cable
Software Included
Drivers & Utilities
4 cm
19.5 cm
11 cm
Package Type
Retail
Scroll to top
