BT.com
Wishlist
Sapphire Technology AMD Radeon R7 250 800MHz 1GB GDDR5 PCI-Express 3.0 HDMI
Delivery
Standard Due date unavailable
The SAPPHIRE R7 250 1 GB now has the GDDR5 memory clocked at 4500 MHz effective, and runs with a core clock speed of 800 MHz.
Sapphire RADEON R7 250 - graphics card - Radeon R7 250 - 1 GB
Graphics card - low profile
Bus Type
PCI Express 3.0 x16
Graphics Engine
AMD Radeon R7 250
1 GB GDDR5
Core Clock
800 MHz
Stream Processors
512
Effective Memory Clock
4.5 GHz
Memory Interface
128-bit
Max Resolution
4096 x 2160
Max Resolution Details
DVI: 2560 x 1600 / DisplayPort: 4096 x 2160 / HDMI: 4096 x 2160
Max Monitors Supported
3
DVI-I (dual link) , Micro-HDMI , Mini DisplayPort , VGA - with adapter , DisplayPort - with adapter , HDMI - with adapter
API Supported
DirectX 11, OpenGL 4.2
1.8 cm x 17 cm x 6.7 cm
Package Type
Lite retail
Bus Type
PCI Express 3.0 x16
Graphics Engine
AMD Radeon R7 250
Core Clock
800 MHz
Stream Processors
512
Process Technology
28 nm
Max Resolution
4096 x 2160
3
API Supported
High dynamic-range (HDR) rendering, Avivo HD Technology, AMD HD3D Technology, AMD PowerPlay technology, AMD CrossFireX Technology, AMD PowerTune technology, AMD Stream technology, AMD App Acceleration, Dolby True HD support, DTS-HD Master Audio support, AMD Eyefinity Technology 2.0, Multi-Sample Anti-Aliasing (MSAA), Graphics Core Next (GCN), AMD ZeroCore Power technology, cutting-edge Quad HD display support, 24x Custom Filter Anti-Aliasing (CFAA)
Size
1 GB
GDDR5 SDRAM
Effective Clock Speed
4.5 GHz
Bus Width
128-bit
Min RAM Size
4 GB
Required Power Supply
400 W
Additional Requirements
CD-ROM
ATX bracket
1 x DVI-VGA adapter , 1 x Mini DisplayPort-DisplayPort cable , 1 x micro-HDMI-HDMI cable
Software Included
Drivers & Utilities, AMD Catalyst Control Center
WHQL
1.8 cm
17 cm
6.7 cm
Package Type
Lite retail
Scroll to top
