BT.com
Wishlist
Sapphire Technology AMD Radeon R7 240 730MHz 1GB GDDR5 PCI-E 3.0 HDMI
Delivery
Standard Due date unavailable
The SAPPHIRE R7 240 1GB with Boost now has the latest GDDR5 memory clocked at 4600MHz effective, and runs with a core clock speed of 730 MHz which with PowerTune Dynamic Boost rises to 780 MHz on the engine.
Specification
  • Display Support 2 x Maximum Display Monitor(s) support
  • Output D-Sub(VGA), 1 x HDMI (with 3D), 1 x Dual-Link DVI-D
  • GPU 730/Boost:780 MHz Core Clock, 28 nm Chip, 320 x Stream Processors
  • Video Memory 1024 MB Size, 128 -bit GDDR5, 4600 MHz Effective
  • Dimension 150(L)X105(W)X15(H) mm Size, 1 x slot
  • Software Driver CD
Sapphire RADEON R7 240 with Boost - graphics card - Radeon R7 240 - 1 GB
Graphics card
Bus Type
PCI Express 3.0
Graphics Engine
AMD Radeon R7 240
1 GB GDDR5
Core Clock
730 MHz
Boost Clock
780 MHz
Stream Processors
320
Effective Memory Clock
4.6 GHz
Memory Interface
128-bit
Max Resolution
4096 x 2160
Max Resolution Details
HDMI: 4096 x 2160 / VGA: 2048 x 1536
Max Monitors Supported
2
DVI-I (dual link) , HDMI , VGA
API Supported
DirectCompute, OpenGL 4.3, DirectX 11.2
1.5 cm x 15 cm x 10.5 cm
Package Type
Lite retail
Graphics card
Bus Type
PCI Express 3.0
Graphics Engine
AMD Radeon R7 240
Core Clock
730 MHz
Boost Clock
780 MHz
Stream Processors
320
Process Technology
28 nm
Max Resolution
4096 x 2160
2
API Supported
Avivo HD Technology, AMD HD3D Technology, AMD PowerPlay technology, AMD CrossFireX Technology, AMD PowerTune technology, AMD Stream technology, AMD App Acceleration, Deep Color technology, Dolby True HD support, DTS-HD Master Audio support, AMD HD Media Accelerator, Multi-Sample Anti-Aliasing (MSAA), Graphics Core Next (GCN), AMD ZeroCore Power technology, 24x Custom Filter Anti-Aliasing (CFAA)
Size
1 GB
GDDR5 SDRAM
Effective Clock Speed
4.6 GHz
Bus Width
128-bit
Microsoft Windows XP Media Center Edition 2005, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Windows 8 (32/64 bits), Windows 8.1 (32/64 bits)
Min RAM Size
1 GB
Required Power Supply
400 W
Additional Requirements
CD-ROM
Software Included
Drivers & Utilities, Sapphire TriXX, AMD Catalyst Control Center
WHQL
1.5 cm
15 cm
10.5 cm
Package Type
Lite retail
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
4* Great for budget and occasional gaming
Reviewed by Anonymous on 06/04/2014
I chose this to replace my blown Inno3D Geforce 7600GST (128Mb), and predictability it walks all over it.
If you're looking to replace an old video card on a budget and occasionally play older titles, then this is good for the money.
It plays Half-Life 2 with everything at max (1440x900), same with Portal 2. Ive not tried other games yet but these are the 2 I play the most.
You could spend a little more and get a much better card, but if like me you want to spend the minimum, but bring an older system a bit more up to date, this is a fine card.
Scroll to top
