BT.com
Wishlist
Sapphire Technology AMD Radeon R7 240 730MHz 4GB DDR3 PCI-E 3.0 HDMI
Delivery
Standard Due date unavailable
The SAPPHIRE R7 240 with Boost now has the latest DDR3 memory clocked at 1800MHz effective, and runs with a core clock speed of 730 MHz which with PowerTune Dynamic Boost rises to 780 MHz on the engine.
Specification
  • Display Support 2 x Maximum Display Monitor(s) support
  • Output D-Sub(VGA), 1 x HDMI (with 3D), 1 x Dual-Link DVI-D
  • GPU 730 MHz Core Clock, 28 nm Chip, 320 x Stream Processors
  • Video Memory 4096 MB Size, 128 -bit DDR3, 1800 MHz Effective
  • Dimension 145(L)X95(W)X15(H) mm Size, 1 x slot
  • Software Driver CD, SAPPHIRE TriXX Utility
Sapphire RADEON R7 240 with Boost - graphics card - Radeon R7 240 - 4 GB
Graphics card
Bus Type
PCI Express 3.0
Graphics Engine
AMD Radeon R7 240
4 GB DDR3
Core Clock
730 MHz
Boost Clock
780 MHz
Stream Processors
320
Effective Memory Clock
1.8 GHz
Memory Interface
128-bit
Max Resolution
4096 x 2160
Max Resolution Details
HDMI: 4096 x 2160 / VGA: 2048 x 1536
Max Monitors Supported
2
DVI-D (dual link) , HDMI , VGA
API Supported
OpenCL, DirectCompute, OpenGL 4.3, DirectX 11.2
1.5 cm x 14.5 cm x 9.5 cm
Package Type
Lite retail
Graphics card
Bus Type
PCI Express 3.0
Graphics Engine
AMD Radeon R7 240
Core Clock
730 MHz
Boost Clock
780 MHz
Stream Processors
320
Process Technology
28 nm
Max Resolution
4096 x 2160
2
API Supported
Avivo HD Technology, AMD HD3D Technology, AMD PowerPlay technology, AMD CrossFireX Technology, AMD PowerTune technology, AMD Stream technology, AMD App Acceleration, Deep Color technology, Dolby True HD support, DTS-HD Master Audio support, AMD HD Media Accelerator, Multi-Sample Anti-Aliasing (MSAA), Graphics Core Next (GCN), AMD ZeroCore Power technology, 24x Custom Filter Anti-Aliasing (CFAA), AMD Unified Video Decoder (UVD), HDCP
Size
4 GB
DDR3 SDRAM
Effective Clock Speed
1.8 GHz
Bus Width
128-bit
Microsoft Windows XP Media Center Edition 2005, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Windows 8 (32/64 bits), Windows 8.1 (32/64 bits)
Min RAM Size
1 GB
Required Power Supply
400 W
Additional Requirements
CD-ROM, adjacent PCI slot
Software Included
Drivers & Utilities, Sapphire TriXX, AMD Catalyst Control Center
WHQL
1.5 cm
14.5 cm
9.5 cm
Package Type
Lite retail
Scroll to top
