BT.com
Wishlist
Sapphire Technology AMD Radeon Pro Duo 8GB HBM PCIe Graphics Card
Delivery
Standard Due date unavailable
Packing two Fiji XT chips and 8 GB of next-generation HBM memory, it's a truly fast graphics card. Virtual Reality and 4K gaming are the benchmarks of Radeon Pro Duo, but the Pro also stands for superior performance in content creation. Gamers, artists and developers alike will all benefit from the extreme 16 teraflops of raw computational power offered by the very first member of the Radeon Pro product family.
The SAPPHIRE Radeon Pro Duo delivers better performance thanks to a pair of the advanced GCN-based AMD Fiji XT chips that collectively feature 8192 stream processors. These cores, clocked at 1000 MHz each, sit on the GPU base right next to the stacks of High Bandwidth Memory - a total of 8 GB with 4096-bit interface and up to 1024 GB/s throughput. Third generation of GCN architecture with asynchronous shaders means full native support for DirectX 12 and Vulkan APIs as well as AMD LiquidVR technology.
Sapphire RADEON Pro Duo - graphics card - 2 GPUs - Radeon Pro Duo - 8 GB
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
2 GPUs - AMD Radeon Pro Duo
8 GB HBM
Core Clock
1000 MHz
Stream Processors
8192
Effective Memory Clock
1000 MHz
Memory Interface
4096-bit
Max Resolution
4096 x 2160
Max Resolution Details
DisplayPort: 4096 x 2160 / HDMI: 4096 x 2160
Max Monitors Supported
4
HDMI , 3 x DisplayPort
API Supported
DirectX 12, OpenGL 4.5, OpenCL 2.0
4 cm x 27.8 cm x 13 cm
Package Type
Retail
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
Core Clock
1000 MHz
Stream Processors
8192
Process Technology
28 nm
Max Resolution
4096 x 2160
4
API Supported
ATI CrossFire Technology, Dual Slot Fan Cooler, Dual Bios, ATI CrossFireX Technology, AMD Eyefinity Technology, AMD HD3D Technology, Shader Model 5.0, Graphics Core Next (GCN), AMD Unified Video Decoder (UVD), AMD TrueAudio Technology, FreeSync Technology, AMD LiquidVR Technology, Virtual Super Resolution (VSR), AMD Water Cooling Technology, AMD High-Bandwidth Memory
Size
8 GB
HBM
Effective Clock Speed
1000 MHz
Bus Width
4096-bit
Bandwidth
1024 GBps
Required Power Supply
800 W
Additional Requirements
CD-ROM, three 8-pin power connectors
300 Watt
4 cm
27.8 cm
13 cm
Package Type
Retail
Scroll to top
