BT.com
Wishlist
Sapphire Technology AMD Radeon 7870 HD 1050MHz 2GB PCI-E 3.0 HDMI Dual-X OC
Delivery
Standard Due date unavailable
The SAPPHIRE HD 7800 series of graphics cards is based on the third family of GPU's from AMD built in its 28 nm process and featuring the highly acclaimed GCN graphics processing architecture.
The SAPPHIRE HD 7870 GHz Edition OC, factory-overclocked to 1050 MHz engine and effective 5000 MHz memory, offers superior performance than standard models. It is equipped with SAPPHIRE's dual-extractor technology - Dual-X - a highly efficient multi-heatpipe cooler with dual fans providing quiet and very cool operation during normal operating conditions, and superb cooling performance even under extreme load.
Sapphire RADEON HD 7870 OC - GHz Edition - graphics card - Radeon HD 7870 - 2 GB
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
AMD Radeon HD 7870
2 GB GDDR5
Core Clock
1050 MHz
Stream Processors
1280
Effective Memory Clock
4.8 GHz
Memory Interface
256-bit
Max Resolution
4096 x 2160
Max Monitors Supported
3
DVI-I (dual link) , HDMI , DisplayPort , DVI-D (Single-Link)
API Supported
DirectX 11, OpenCL, DirectCompute, OpenGL 4.2
2.9 cm x 22.5 cm x 11.5 cm
Package Type
Lite retail
Microsoft Certification
Compatible with Windows 7
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
AMD Radeon HD 7870
Core Clock
1050 MHz
Stream Processors
1280
Process Technology
28 nm
Max Resolution
4096 x 2160
3
API Supported
Avivo HD Technology, AMD HD3D Technology, AMD PowerPlay technology, AMD CrossFireX Technology, AMD PowerTune technology, AMD Stream technology, dual slot heatsink, AMD App Acceleration, Dolby True HD support, DTS-HD Master Audio support, AMD Eyefinity Technology 2.0, AMD HD Media Accelerator, Dual-X cooler, Multi-Sample Anti-Aliasing (MSAA), Graphics Core Next (GCN), AMD ZeroCore Power technology, 24x Custom Filter Anti-Aliasing (CFAA)
Size
2 GB
GDDR5 SDRAM
Effective Clock Speed
4.8 GHz
Bus Width
256-bit
Min RAM Size
1 GB
Required Power Supply
500 W
Additional Requirements
CD-ROM, 2 x 6 pin PCI Express power connector
2 x 4 pin to 6 pin power cables
1 x CrossFire internal bridge , 1 x DVI-VGA adapter
Software Included
Drivers & Utilities, Sapphire TriXX, AMD Catalyst Control Center
Supported Windows 7 Features
Windows Media Center
2.9 cm
22.5 cm
11.5 cm
Package Type
Lite retail
Scroll to top
