BT.com
Wishlist
Sanyo Replacement lamp for PLC-HP7000
Sanyo Replacement lamp for...
£466.23
Hurry, only 2 left in stock!
£466.23
Add to wishlist
Delivery
Standard 1-3 working days
The projector PLC-HP7000L supports Full HD resolution without any image compression. Advanced optical QuaDrive engine achieves the high brightness of 7000 lumens with just one high-output lamp in the compact black long-lasting body.
SANYO's Unique QuaDrive engine evolves into a new generation standard. The color control device in the QuaDrive optical engine allows the PLC-HP7000L to automatically control the amount of yellow light in the image, producing higher luminosity with improved color accuracy and clarity.
Sanyo projector lamp
Projector lamp
PLC-HP7000L
Projector lamp
Sanyo PLC-HP7000L
Scroll to top
