BT.com
Wishlist
Sanyo 2200 ANSI Lumens XGA Projector
Delivery
Standard Due date unavailable
Not much larger than a laptop PC, the PLC-XD2200 weighs less than 5.7 pounds and delivers true XGA picture quality in a versatile, go anywhere system.
PLC-XD2200 provides "auto set up function" that corrects keystone shaped distortion by searching for an input signal and detecting projector incline, therefore reducing set up time. PLC-XD2200 automatically compensates for keystone picture distortion. Auto keystone correction, auto input search and auto PC adjustment make it an easy to use smart projector.
This model is equipped with Wired LAN (RJ-45) that allows you to manage and control the projector via network. It is possible to check the operating time of lamp and manage the warning notification by email. Power on/off and switching of the input signal can be controlled.
The PLC-XD2200 offers excellent flexibility via a pair of D-sub15 RGB and Audio input terminals. This model can be used with Dual D-sub15 and dual audio input and also trading audio output follows input source to audio output automatically. One of the D-sub15 terminals can even be switched between input and monitor output for greater programming flexibility.
The PLC-XD2200 allows saving your total cost of ownership with equipping ultra long life lamp. This lamp enable to be used 6000H with eco mode in ideal condition.
Sanyo PLC-XD2200 LCD projector
LCD projector
Built-in Devices
Speaker
Brightness
2200 lumens
Contrast Ratio
500:1
Resolution
XGA (1024 x 768)
Native Aspect Ratio
4:3
Bulb type
UHP 215 Watt
Bulb life cycle
Up to 4000 hour(s) / up to 6000 hour(s) (economic mode)
Video Input
RGB, S-Video, composite video, component video ( NTSC, SECAM, PAL, PAL-N, PAL-M, NTSC 4.43 )
Video Modes
480p, 720p, 1080i, 480i, 1035i, 575i, 575p
Video Output
RGB
Speakers
Speaker(s) - integrated
AC 120/230 V
210 Watt
33.4 cm x 24.7 cm x 9.4 cm
2.6 kg
3 years warranty
LCD projector
Built-in Devices
Speaker
Projector
Brightness
2200 lumens
Brightness (Reduced)
1540 lumens
Contrast Ratio
500:1
Image Size
102 cm - 762 cm
Projection Distance
1.3 m - 11.8 m
Throw Ratio
1.62 - 1.92:1
Uniformity
85 %
Resolution
XGA - XGA (1024 x 768) (native) / 1920 x 1200 (resized)
Native Aspect Ratio
4:3
Video Bandwidth
140 MHz
Max Sync Rate (V x H)
100 Hz x 100 kHz
Bulb type
UHP 215 Watt
Bulb life cycle
Eco-Mode technology, freeze frame, Blackboard Mode, integrated de-interlacer (progressive scan), 2:2 pull down compensation, 3:2 pull down compensation
Lens
Focus Type
Manual
Lens Aperture
F/2.0-2.15
Zoom Type
Manual
Zoom Factor
1.2x
Keystone Correction Direction
Vertical
Vertical Keystone Correction
-30 / +30
Video Input
TV System
Analogue video Signal
Video Interfaces
VGA, composite video
Video Modes
Video Output
Analogue Video Signal
RGB
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
1 Watt
Speakers
1 x mixed channel
Input Device
External
Movement Detection Technology
Infrared
1 x component video / RGB / S-video - 15 pin HD D-Sub (HD-15) , 1 x VGA input / output - 15 pin HD D-Sub (HD-15) , 1 x composite video input - RCA , 1 x audio line-in - mini-phone stereo 3.5 mm , 1 x audio line-out - RCA x 2 , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x serial RS-232 - 9 pin D-Sub (DB-9) ( management ) , 1 x network - RJ-45 ( management )
Lens cover, wireless remote control
1 x VGA cable
Security Features
Security lock slot (cable lock sold separately), control panel lock, PIN code
Nominal Voltage
AC 120/230 V
210 Watt
Power Consumption Operational (Standby)
0.7 Watt
33.4 cm
24.7 cm
9.4 cm
2.6 kg
Limited warranty - 3 years , Limited warranty - lamp - 1 year / 2000 hours
Sound Emission
34 dB
29 dB
Accessories
Sanyo - Projector lamp
Quicklinx: 7BPW | In Stock
£82.60
Scroll to top
