BT.com
Wishlist
Sandisk Ultra Secure 16GB SD Card - 30MB/s - Class 10 - SDHC UHS-I
Delivery
Standard Due date unavailable
Twice as Fast as Ordinary Cards to Take Better Pictures and Videos
Combining fast performance and generous capacity,the SanDisk Ultra SDHC or SDXC UHS-I memory card is an ideal storage choice for compact to mid-range point-and-shoot cameras and camcorders. This versatile card offers twice the speed of an ordinary memory card, so you can take more pictures with less lag time. These cardscome in a variety of capacities and feature a shock-resistant, water and temperature-proof design. Don't miss the moment. Be ready with double the speed and the highest video performance.
  • Highest video performance with Class 10 rating for Full HD video (1080p)
  • Best choice for compact to mid-range point and shoot cameras
  • Quick transfer speeds up to 30MB/s
  • Durable and reliable
Class 10 Performance for Seamless Full HD Video Recording
A class 10 video performance rating makesthis card ideal for HD camcorders and Full HD (1080P) video enabled cameras.
Storage Capacities up to 64GB
SanDisk Ultra SDHC and SDXC UHS-I cards have plenty of room to accommodate high-resolution image formats, such as RAW and JPEG. Available in sizes up to 64GB, these cards can store thousands of photos and all your favorite video clips.
Fast Read Speed Reduces Upload Time
The card boasts a read speed of up to 30MB/s, so you can transfer photos and videos to your computer quickly and easily. You'll be able to edit, store, and share your photos faster than ever before.
Durable Design
SanDisk Ultra SDHC/SDXC UHS-I Cards are designed to handle whatever life throws at them. These cards are shockproof (Capable of withstanding up to 500Gs of shock), X-ray proof (Immune to airport X-rays), and waterproof (Tested to withstand up to 72 hours in 1m salt or fresh water; IEC 529 IPX7; product must be clean and dry before use). The card operates in temperatures ranging from -13 to 185 degrees Fahrenheit, so you can capture memories in almost any climate. Your SanDisk memory card will survive, even if your camera doesn't.
Warranty
The SanDisk Ultra SDHC/SDXC UHS-I Memory Card is backed by a lifetime limited warranty.
SanDisk Ultra - flash memory card - 16 GB - SDHC UHS-I
Flash memory card
SDHC UHS-I Memory Card
Storage Capacity
16 GB
Speed Rating
Class 10
Latin America, Middle East, Africa, Europe, Pacific Rim
Microsoft Certification
Compatible with Windows 7
Limited lifetime warranty (Germany and regions not recognizing limited lifetime warranty - 10 years)
Flash memory card
Storage Capacity
16 GB
Compatibility
Non-specific
SD Speed Class
Class 10
Read Rate
Up to 30 MB/s
Case
Limited warranty - lifetime
24 mm
32 mm
2.1 mm
-25 °C
85 °C
Resources
The following resources are available for the Sandisk Ultra Secure 16GB SD Card - 30MB/s - Class 10 - SDHC UHS-I
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
1* sandisk 16GB SD memory card
Reviewed by barry forbes-bell on 14/10/2013
I purchased this card elsewhere last December but recently my camera said the card was 'locked'. I then discovered for the first time a previously unoticed miniature 'slide' on the side which had moved to a locked position. This happened a second time but this time I discovered the locking slide was missing which meant the card could not be used and my photographs locked in. I then read reviews to find this was a common problem which Sandisk offered to replace provided I supplied photographs of the card and posted in in very precise packaging to my non-refundable cost to the Czech Republic!!! It will now be destroyed along with my photographs.Very disappointed with Sandisk as I presume a market leader.
Scroll to top
