Click to visit BT.com
BT.com
Wishlist
SanDisk Mobile Ultra Android - 32 GB - microSDHC UHS Class 1 / Class10 - Inc Adaptor
Quicklinx: 8906WS00
Mfr#: SDSDQUA-032G-U46A
Get faster app performance and advanced photo and video capture for Android powered or other smartphones and tablets. With speeds up to 30MB/s and highest available Class 10 speed rating and UHS Speed Class 1 (U1) for recording uninterrupted Full HD video, SanDisk Ultra cards are the perfect choice to store your mobile life.
Mobile Ultra
Class 10 Speed Rating for Seamless Video Capture
This memory card features Class 10 and UHS Speed Class 1 (U1) video ratings -- the fastest classifications available for a microSD card. You'll be ready to capture cinema quality 3D and Full HD(1) without dropouts and stuttering.
Fast Photo Capture and Data Transfer
With transfer speeds of up to 30MB/s (Up to 30MB/sec read speed; write speed lower. Based on internal testing; performance may be lower depending upon host device. 1 megabyte (MB) = 1 million bytes), the card brings faster read and write speeds to your camera, mobile phone or HD camcorder. Up to twice as fast as an ordinary memory card, the SanDisk Ultra microSDHC and microSDXC memory card enables your camera or mobile device to quickly snap continuous pictures so you'll never miss a moment.
SD Adapter for Versatility
This microSD card comes with a convenient SD card adapter, so you can capture and access data on the card with any device with an SD card slot. You'll be able to use your card with SD enabled cameras, camcorders, tablets, and laptops.
Durable Design
The SanDisk Ultra microSDHC and microSDXC UHS-I Memory Card captures photos in all conditions with its shockproof (Capable of withstanding up to 500Gs of shock), waterproof (Tested to withstand up to 72 hours in 1m salt or fresh water), and X-ray-proof (Immune to airport X-rays) design. You'll never have to miss those moments even in extreme temperatures from -13 to 185 degrees Fahrenheit.
Warranty
The SanDisk Ultra microSDHC/microSDXC UHS-I Card is backed by a lifetime limited warranty.
(1) Full HD video(1920x1080x30fps) and HD video support may vary based upon host device, file size, resolution, compression, bit rate, content and other factors. See www.sandisk.com/HD video (1080p)
SanDisk Mobile Ultra - flash memory card - 32 GB - microSDHC UHS-I
Flash memory card
microSDHC UHS-I Memory Card
Storage Capacity
32 GB
Speed Rating
Software Included
SanDisk Memory Zone
Flash memory card
Storage Capacity
32 GB
Compatibility
Non-specific
SD Speed Class
Read Rate
Up to 30 MB/s
Shock-proof, waterproof, X-ray proof, temperature proof
Software Included
SanDisk Memory Zone
Resources
The following resources are available for the SanDisk Mobile Ultra Android - 32 GB - microSDHC UHS Class 1 / Class10 - Inc Adaptor
