BT.com
Wishlist
Sandisk Extreme USB 3.0 64GB
Delivery
Standard Due date unavailable
The SanDisk Extreme USB Flash Drive packs unparalleled transfer speeds and generous capacity into a pocket-sized package. Boasting data transfer rates up to 190MB/s, this USB flash drive can transfer files up to ten times faster than an ordinary USB 2.0 flash drive. And with up to 64GB of storage capacity, the drive can accommodate all your important personal files and documents. Outfitted with SanDisk's latest flash memory technology, the SanDisk Extreme 3.0 USB Flash Drive dramatically reduces the time you'll spend waiting for files to transfer. Fully enabled for USB 3.0 ports, the drive can achieve transfer speeds of up to 190MB/s, which means even the largest files will transfer in seconds. You'll be able to move and store HD videos, high-resolution photos, and other bulky files in an instant. Featuring a sleek black colour scheme, the SanDisk Extreme USB Flash Drive is as stylish as it is functional. Thanks to the drive's compact, slim design, you can easily slip it into a pocket.
  • Exceptional file transfer speeds up to 190MB/s
  • Drives up to 64GB can hold your most important data
  • Password protection with SanDisk SecureAccess Software
  • Includes 2GB of online backup via YuuWaa cloud storage
  • USB 3.0 enabled for super-fast transfer speeds
SanDisk Extreme - USB flash drive - 64 GB
USB flash drive
Interface Type
USB 3.0
Storage Capacity
64 GB
Encryption Algorithm
128-bit AES
Enclosure Colour
Software Included
SanDisk SecureAccess 3.0
Microsoft Windows XP, Microsoft Windows 7, Microsoft Windows Vista, Apple MacOS X 10.5 or later
USB flash drive
Storage Capacity
64 GB
128-bit AES
Enclosure Colour
Compatibility
Non-specific
Read Rate
Up to 190 MB/s
Interface Type
USB 3.0
Password protection, retractable connector
Software Included
70.87 mm
21.34 mm
11.43 mm
45 °C
Scroll to top
