BT.com
Wishlist
SanDisk Cruzer Fit - USB flash drive - 16 GB - USB 2.0
Delivery
Standard Due date unavailable
Whether it's your favorite music or your most important work documents, the Cruzer® Fit™ USB flash drive gives you the storage you need in a compact and portable device.
With its low-profile design, the Cruzer® Fit™ USB flash drive easily fits USB ports and blends in with your notebooks, tablets, TVs and car audio systems. Whether it's your favorite music, pictures, music collection, video collection or your work documents, the Cruzer® Fit™ USB flash drive gives you the ever-present storage you need in a compact and portable device. Protect access to your private data with the included SanDisk® SecureAccess™ software, and get the added protection of secure online backup (up to 2 GB optionally available) offered by YuuWaa™.
When your data matters, you can trust SanDisk®.
Highlights
Low profile
LED to monitor drive's activity
Store, protect and transfer your videos, music, photos, or other files
Password protect and encrypt your private files with SanDisk® SecureAccess™ software
Added protection with secure online backup (up to 2 GB* optionally available) offered by YuuWaa™
USB flash drive
Interface Type
USB 2.0
Storage Capacity
16 GB
Encryption Algorithm
128-bit AES
Europe
Software Included
SanDisk SecureAccess
Microsoft Windows Vista / XP / 7, Apple MacOS X 10.5 or later
Microsoft Certification
Compatible with Windows 7
5 years warranty
USB flash drive
Storage Capacity
16 GB
128-bit AES
Compatibility
Non-specific
Europe
Interface Type
USB 2.0
Encryption support, password protection, LED access indicator
Software Included
Limited warranty - 5 years
14.7 mm
21.6 mm
6.9 mm
2.5 g
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
5* incredibly handy!
Reviewed by Adam on 20/11/2012
Order one day, received the next, thanks again BT for a great customer service! these teeny tiny usb sticks are fantastic for people on the go. ordered 10 of them for colleagues (mobile tech engineers). fits on a keyring, and the usb comes with a cap to protect it. for the price, you really can't go wrong with this ultra portable, high capacity USB drive. A+++ product!
4* Small but fragile
Reviewed by Don Reid on 06/07/2013
It is a technological miracle to get 16GB in such a small size. Works extremely well. However, the mounting ring is too small to fit most keyrings directly. It is very fragile and doesn't withstand the weight of a bunch of keys. After a few days the ring broke, rendering the usb stick pretty useless as it is so small it's going to get lost.
Scroll to top
